Din Rail Toggle Switch
/ Din Rail Toggle Switch #1
Professor Marvel
Virginia near Culpeper
Ford 5000, Kubota 2150 HST, NH TC45 D, JD 375 Baby Skid Steer --- STUFF THAT GOES ON EM, Schwinn Stingray
Not on tractor topic but everybody here works on all sorts of things so I hoped I could get direction.
I am looking for a supplier for simple din rail mounted toggle or rocker switches for inside a control panel.
Thanks for any help.
/ Din Rail Toggle Switch #2
I think I've seen that in the MSC catalog.
I think their website is:
mscdirect.com
/ Din Rail Toggle Switch #3
You do know how Google works? Just put "DIN rail toggle switch" into the search line. You'll come up with suppliers like Amazon.com, Newark, etc. Really - it's not all that complicated or difficult...
/ Din Rail Toggle Switch #4
Why don't you just use a DIN rail mount circuit breaker as a switch?? You can buy them for less than $10.
The circuit breaker looks like my best choice so far. I will probably end up with that. I was just hoping for a slightly different look for my customer. I didn't think it would be so difficult to find.
thanks
Apparently I have a Google that is far inferior to swines
/ Din Rail Toggle Switch #7
thanks
I use Google Images for this type search.
Found this: https://www.google.com/url?sa=i&rct...DL4P7wSQDDe5bT5JVm3Q-ylg&ust=1431983490655372
425270-din-rail-toggle-switch-31hcur1v0zl-_sx342_-jpg
ended up using a breaker
thanks all
/ Din Rail Toggle Switch #11
yes I had seen this but they wanted something like 65 bucks for it. It's a light switch and i couldn't bring myself to spend that for a light switch. I thought it should be easy to find a switch on a din rail hanger for about 5 bucks. Guess not
Thanks for checking for me
Your'e welcome. I learned what Din Rail is. :D
/ Din Rail Toggle Switch #13
Deutsches Institut für Normung e.V.(DIN; in English, the German Institute for Standardization) is the Germannational organization for standardizationand is the German ISO member body. DIN is a Registered German Association (e.V.) headquartered in Berlin. There are currently around thirty thousand DIN Standards, covering nearly every field of technology.
/ Din Rail Toggle Switch #14
Yes, but do you know what DIN stands for?
I do, I do.:jump::jump: Deutsche Institute for Normalization. Or something pretty close to that....
German institute for standardization in other words.
/ Din Rail Toggle Switch #15
well, heck,, what is the point of asking a trivia question, if you are going to answer it yourself..:shocked:
/ Din Rail Toggle Switch #16
And now I know what DIN is. :D
/ Din Rail Toggle Switch #18
And I bet you thought a DIN was just a big loud noise!:)
Yep, have been in DIN without earplugs! :eek:
But I like din-din. :thumbsup:
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
UNUSED SDLANCH STAND ON SKID STEER (A64280)
UNUSED SDLANCH...
2007 Ford Taurus Sedan (A61574)
2007 Ford Taurus...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
(2) BUCKETS OF ASSORTED ROOFING NAILS (A64281)
(2) BUCKETS OF...
