ripper for roots?
/ ripper for roots? #1
Luke'sScreenName
Elite Member
Lakes Region, NH
Kubota MX4800 with BH-90X hoe; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
So I have a new Kubota MX4800 and a Bradco Jaws tree and post puller. It works amazingly well but the biggest hardwood I can pull is 6 or 7 inches in diameter. I can use my subsoiler to loosen the soil around larger trees to get them out but it tend to get hung-up on lager roots.
I have been thinking about making a pointed blade for the subsoiler to cut the roots better. But i came across a homemade ripper on Craigslist for less than i could buy the metal.
I'm going to go look at it (buy it) in the morning. I was wondering what some of the more experienced implement fabricators thought of it. Any chance it will work or will I rip it to shreds?
/ ripper for roots? #2
I think you should have fun trying it out. I've no idea if it is up to the task or not. If inexpensive enough certainly worth the try.
/ ripper for roots? #3
Plan on the resistance of the root equal to trying to split wood 'cross grain". 20 ton is just enough ;-)
Sharpen that blade, and peck away !
/ ripper for roots?
Do the tree sheer attachments produce that much force? Just curious where you got the 20ton number?
/ ripper for roots? #5
I am interested to know how well it works.
Have been thinking about one for my machine.
/ ripper for roots? #6
i have a piece of flat bar that has cut and sharpened notches in it. I push my pallet forks together, tack weld it to the bottom, then push the forks in around the roots using it as a saw and you can rip the roots all the way around, then push the tree over and get up under the root ball. grind weld off when done.
/ ripper for roots? #7
Pics or video of your tree puller in action or it doesn't exist :). Please
/ ripper for roots?
It work ok. A lager blade might actually be better. Haven't torn it up yet. Largest hardwood root that i know I've cut was about 3.5" diameter. Also it would be better if it were set further away from the tractor making it easier to back up to a tree and make a cut on either side of it.
I also posted a video of the tree puller in action. Did not need the ripper for those trees. Search for "tree puller" in the titles.
/ ripper for roots?
<img src="http://www.tractorbynet.com/forums/files/attachments/426472-ripper-roots-20141217_131958-jpg"/> this works for me
Awesome!
/ ripper for roots? #13
its for sale for $650. was just about twice that in steel to make it.
