tire gauge
/ tire gauge #1
jcummins
Creal Springs, IL
Kubota M7040, F3680, Mule Pro Fxt
All of the various ones I've had, are now in the trash. Seems they work ok for few weeks, then crap out.
Is there any decent reliable gauges out there that aren't expensive? Are digitals any good?
/ tire gauge #2
Catch 22- How do know they're no good if you don't have one you can trust to compare it to?
I use to have about a 7 or 8 cheap gauges in a tin. I get samples readings of say 29, 31, 32, 32, 33, 34, 36. Now, what's the real tire pressure? That is were statistics, faith, and/or your belief in democracy might get questioned (sorry I'll try not to get political) ;).
So I went and bought a digital one for about $30 that according to the package is accurate to (I think) .2% and threw out any of the old gauges that didn't measure within +/- 1 psi of the digital.
/ tire gauge
How do I know it's no good??? Take a reading and the gauge slams to it's highest reading....and the tire is low. The top blows off of it.... Take a reading, take another reading, take another reading, and they all read different pressures. SO, I know it's not correct. Over time, all of the pencil types I've had end up that way.
Is the $30 digital worth it? I'm wanting to know that...AND which one is a decent one. Being digital doesn't mean it's good.
/ tire gauge #4
Our horse trailer tires require 110 PSI, some digital gauges don't go that high.
I bought an Accutire gauge at Sears many years ago, had a 5 year warranty, The center pin that opens the valve in the valve stem is plastic and wears out. Every three or four years when it quits opening the valve, I take it to Sears and exchange it for a new one.
Works good gets the same pressure reading as the one in my truck. Accutire Gauge | Standard Digital Tire Gauge and Programmable Digital Tire Gauge
attachment.php
/ tire gauge
Xfaxman that looks like what I'm looking for. Thanks.
/ tire gauge #6
I gave up on the spring type and just use a Craftsman digital. I do have an old one that works like a pressure gauge with a Bernoulli tube inside that reads the same as the digital but without my glasses or at night it is useless so I just stick with the Craftsman. I think it was about $30 also. I had one quit working, took it back and got a new one no problem.
I also had one of the Accurite ones but it also quit working after a few years and no way to replace the battery. As far as I know, it gave good readings as long as it worked. I like the Craftsman better because it has a bleeder valve on it so you can remove air easy if you overpressure. It measures in .5 psi increments which is close enough for me in all but my Goldwing front shock which only take 6 PSI max and requires a special inflation hand pump to air them up. You want to get them exactly the same so .5 PSI is a large variant when you want 4min to 6 max. and just putting on the digital gauge will loose 4 PSI (the air volume is so small)
/ tire gauge
Gary you have a model number on that Craftsman? They have different models.
I could of used at one time the 110lb limit Xfaxman has, but 75lb limit would be nice, since I do air my Duramax to that pressure if I've got heavy stuff in the bed.
/ tire gauge
/ tire gauge #10
I haven't used anything but this style since I discovered them in the 60's.
No failures.
Bruce
/ tire gauge #11
I use the one like Bruce uses. Have for 15 years.
Will
/ tire gauge #12
Like others, I haven't found a way to know whether my gauges are accurate or not. But, that aside, I use the digital Accru-gage with the flex-hose and a clamp on type filler valve. I am able to replace the battery in mine, which I really like. I think I paid something like $40 for it.
The other supposedly top brand is a M****n. Paid $50+ for that one. It quit on me after about a year, and there's no cheap way to fix it, other than buy another M****n.
/ tire gauge #14
I have an old gauge that was my dad's... when he was in charge of maintaining a fleet of DC-9s, accurate tire pressures were required, and he had a reference pressure gauge that was certified dead on 60psi- I use that to compare regular tire gauges, to see what they read. I have one of those Sear's digital gauges, and it seems close enough.
/ tire gauge #15
I am not sure if one good gauge would be cheaper than 7 bad ones? They say a poor man should only buy the better equipment, he cannot afford to keep replacing the bad.
It is a bit like a clock, if you have several you never really know the correct time because they all are different.
I use one similar to the one posted above and it has worked well for me but my tires have no fluid in them. I was like you in the beginning, I had some cheap ones and have been much happier with a better one and it now has worked for 10 years or so.
/ tire gauge #16
/ tire gauge #17
I have the same problem. Five gauges priced high to low and no two read the same.
/ tire gauge #19
425970-tire-gauge-accutire-ms-4021b-standard-digital
Good choice! ConsumerReports.org did a report (October 2013) on tire pressure gauges and "tested them for accuracy, ease of use, and durability, and also checked to see how they were affected by ambient temperatures spanning a range from just above freezing to 113-118 degrees F". Two digital Accutire gauges topped the ratings, the MS-4400B and the MS-4021B which is model you chose.
Also...this site has more about gauges.
Comparison Tests on Tire Pressure Gauges
/ tire gauge #20
Thanks, that is good to know.
Also, these have a replaceable battery. :thumbsup:
2011 Terra Riser 300D-SA Fire Plow Tractor Attachment (A61572)
2011 Terra Riser...
2000 CATERPILLAR 988F WHEEL LOADER (A60429)
2000 CATERPILLAR...
ROTO-FINGER PEA - BEAN SHELLER (A63291)
ROTO-FINGER PEA -...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
2005 Chevrolet Impala Sedan (A61574)
2005 Chevrolet...
