Mowing With A CK27 30 or 35
   / Mowing With A CK27 30 or 35 #1
Hdoilcan
Gold Member
USA
2018 KIOTI CK3510SE CAB, 2475L BACKHOE, 72 BOX BLADE, 72 REAR BLADE, 72 LANDSCAPE RAKE, 1,250 LB 55 GAL DRUM BALLAST, 2018 FERRIS IS 700Z, 26HP 810 VANGUARD ENGINE
I would like to hear your mowing experience with a ck 27 30 or 35. Is it to heavy for your lawn...... does the R4 tires rip up the lawn? How well does it maneuver around in tight spaces? Anything else I need to know.
I was looking at the ck35 and the ck2510. I like the size of the ck2510 but the I like the specs better on the ck35. I like how the ck35 has a three speed hydro vs the two speed hydro. I will be using it for mowing, moving fire wood, leveling the driveway, plowing the driveway and any other yard maintenance. I will purchase a backhoe for it to. I already have a few attachments that are SSQA and the ck35 has the SSQA where as the ck2510 doesn't. I have a 6' box blade to I think will be to big for the ck2510.
Any opinions welcome.
   / Mowing With A CK27 30 or 35 #2
It depends on what your lawn looks like and conditions of the soil. My ck27 is way to heavy and would damage my lawn if I mowed with it. Hence I use a 72 inch scag to take care of things in a jiffy.
   / Mowing With A CK27 30 or 35 #3
+1 I have the 27 as well and depending on the ground and how wet it is, it can rip up the ground.
Also, it is a tractor. They maneuver like a barge.
Looking at your profile, you already have some good size machines. Are you looking to replace one or supplement? If it is a supplement, I would go with the slightly smaller equipment.
I'm looking to replace my L3540. I want a tractor big enough to do things already mentioned but also be able to mow. I really like the size of the ck2510 but I'm nervous about it not having that mid range. I only have 1.5 acres with the option of purchasing two more. I have the funds for a ck35 and really would like to purchase it but not if its not going to work for mowing in my situation. My yard slopes down a little bit on one side of the house and there's a small stream that comes from a pipe under the road on that side of the property. I should say it starts of as a stream and then it goes into and area of all cat tails. It makes that side of the property a little wet during the spring time and early summer. I plan to get in there with a backhoe and dig a wide ditch to hopefully solve that problem. Otherwise the feast of the yard is pretty solid.
   / Mowing With A CK27 30 or 35 #5
I use my 35 all summer to mow with a rear finish mower. It does a fantastic job, and Turf tires are the only way to go. If your grass / lawn is wet and spongy the 35 or any large lawn tractor will leave makes and even rip it up a bit. I just wait until the lawn is dry in the spring before I start mowing with the 35.
I had a CK20 before the 35.....Night n - Day in the difference, the 35 is such a better all around tractor. (for Me anyway)
   / Mowing With A CK27 30 or 35 #6
I have a Bobcat ct235 so very similar to Kioti.
I mow all the time but have turf tires. I get no issues on tearing up the grass. I also have no complaints about having turf tires when doing simple loader work like moving dirt/mulch or rocks. I have never lacked for traction --- but I don't really do intense type of work.
You need to be careful if it is too wet --- but that is common sense.
Like someone said, its a tractor so turning and manuvering is not the smoothest or mose efficient.
I also have zero turn for the more wooded areas. The zero turn dammages the grass much more than the tractor if I am not cafeful on turns.
Good luck.
MoKelly
2023 Sundowner Rancher Express 24FT Livestock Trailer - All-Aluminum Stock Hauler (A55302)
2023 Sundowner...
Pratt 8.5ft Flatbed Tilt Trailer (A55787)
Pratt 8.5ft...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A56435)
2008 Ford F-250...
Honda Pioneer SXS700 4X4 Utility Cart (A55787)
Honda Pioneer...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A56435)
2022 Schulte...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
