Don't use brush mower with trailer hitch kit installed on 3032e!
   / Don't use brush mower with trailer hitch kit installed on 3032e! #31
I have a 3 point hitch rotary cutter brush hog. It can't hook it up to a trailer hitch. Or am I missing something hear.
Trailer hitch and a PTO shaft sound like trouble to me.
   / Don't use brush mower with trailer hitch kit installed on 3032e! #32
I have a 3 point hitch rotary cutter brush hog. It can't hook it up to a trailer hitch. Or am I missing something hear. Trailer hitch and a PTO shaft sound like trouble to me.
Scroll up to the first post to see what your missing.
Sent from my iPad using TractorByNet
   / Don't use brush mower with trailer hitch kit installed on 3032e! #33
I got it now. Thanks
   / Don't use brush mower with trailer hitch kit installed on 3032e! #34
I will be removing my draw bar tonight on my 3032E. I don't have a ball on it but if it fell out it could still do some damage.
   / Don't use brush mower with trailer hitch kit installed on 3032e! #35
I've never suffered the damage the OP has. But I lost a drawbar once. Brush unclipped it and the pin fell out. After searching in a timber where I was cutting trails for 3 hours I finally found the drawbar. I never brush cut with a drawbar installed now. Steep learning curve. :)
   / Don't use brush mower with trailer hitch kit installed on 3032e! #37
Ya can't JB Weld, or any other quick remedy, this problem if you intend to use the drawbar to it's maximum capability.
   / Don't use brush mower with trailer hitch kit installed on 3032e! #38
Ok, Plan B: Get the tractor to Sodo and his 120 VAC welder. Problem solved.
[did i really go there?]
   / Don't use brush mower with trailer hitch kit installed on 3032e! #39
Man that is such a bummer. Maybe the outcome will be favorable. Hopping the best for you and thanks for sharing.
The dealer said they are submitting the estimate to the insurance today. I hope they repair my tractor. I don't want a new one. Mine is already broke in, and it is the last model year without the new emissions equipment. I'd rather not have more unnecessary and expensive parts that can break. I like simple.
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
(10) CORRAL PANELS (A52708)
(10) CORRAL PANELS...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
2017 FREIGHTLINER M2 106 (A55745)
2017 FREIGHTLINER...
TARTER CATTLE MASTER HEAD GATE (A58374)
TARTER CATTLE...
