Split-dovetail car hauler trailer
/ Split-dovetail car hauler trailer #241
I finally got my linear actuator in and installed. I made two brackets for it and welded them on. It was kind of a pain getting everything to work in an enclosed space but I finally made it work.
Hey, I think I recognize that actuator. Linear Actuator IP66 | Progressive Automations
If that's the one, how do you like it? I plan to use one to "automate" the SSQA levers on my Kubota (8" travel).
And yeah, an automated lid is pretty sweet. Should totally youtube that one up.
It's a little different (the electric motor is inline with the cylinder on mine) but it works great. It's also remote controlled.
/ Split-dovetail car hauler trailer #243
What is it / where did you get it? Maybe it's a better option for me, too.
Thanks!
/ Split-dovetail car hauler trailer #246
Nice every trailer should have that. What will be even better is telling s friend to grasp strap out of the box and you raise lid for him.
/ Split-dovetail car hauler trailer #247
When you welded on the spring mounts and the tongue, how did you square everything up? You said it tows nicely so that's a good sign that it tracks straight down the road. I'm thinking of building a trailer one day, and have been curious how precise the axle location needs to be?
Very nice build, btw.
I put the tape measure at the center of the hitch, and made sure that measurement was the same from there to the axle on both sides. That's where the truck is pulling it from, so I figured that was the critical spot. The frame of the trailer can be a little out of square, the a-frame can be a little off, but this pulling point to the axles measurement should make it pull nice behind the truck.
I reworked my safety chains, got the old mounts off with my grinder and welded the new connectors on.
I also added a hitch light, not sure if it'll work with the angle its at, we'll see, I hid the switch under the trim piece of diamond plate. I also added a light inside the toolbox, hope to wire it so it come's on when the lid raises. The weather is supposed to be good Wed. and Thur. and i'm off work...time to paint.
/ Split-dovetail car hauler trailer #250
have you thought of adding a hanger in the side of the tongue to hang the safety Chains from when them trailer isn't hooked up? Something so they aren't just sitting on the ground?
Yanmar YT359 (A53317)
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2014 Chevrolet Silverado (A60352)
2014 Chevrolet...
2021 CATERPILLAR 303.5E2CR EXCAVATOR (A62129)
2021 CATERPILLAR...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
