30" LED Lightbar install on 5 series cab tractor
   / 30" LED Lightbar install on 5 series cab tractor #11
Looks good I think my 4720 need them front and rear.. How good are the deere lights? Havent tried them at night yet. O like that led look..
   / 30" LED Lightbar install on 5 series cab tractor #12
Great job. I would like to see some close up pics of the mounting bracket if you have time to post a few pics of it.
   / 30" LED Lightbar install on 5 series cab tractor #13
You inspired me this morning, I went and put four new lights on the back of my 5083. The picture at a distance is 100' at 10:00 pm.
Deere factory lights are halogen I think. Mine has stock ones on the rear and they are ok. It gets to dusty before I run out of light. On the front end, the only lights were on the hood and the loader would block it. At night it was terrible trying to do anything.
I'll try to snap some tomorrow. I'm sure there's an easier or better way to do it and if I made another set I know what I'd do differently but it works really well
Brett
That made a huge difference. Looks good! Anything for the front yet?
Brett
   / 30" LED Lightbar install on 5 series cab tractor #16
Planning on a light bar similar to yours. I will leave the forward lights I already have though and go with a narrower light bar. I also realized I need a flood mounted on the front right cab corner to light up in front of my mower better.
I can see the mower great, it's the area in front of the mower that's the problem now.
   / 30" LED Lightbar install on 5 series cab tractor #17
mj
What are we seeing in the pic? I'm thinking the green is a fender of the 5083, but what is the orange attachment ??
   / 30" LED Lightbar install on 5 series cab tractor #18
The orange attachment is my Kuhn gmd600 hd disc mower. The curtain is removed to be replaced. That is a view out the side rear window of the 5083.
Not the best pic. I used material I had around the house. 1" sch 40 pipe with a plate welded at the top and drilled for bolt. Fire hose washer for abrasion/vibration resistance. 2" flat bar coming off pipe and another piece of 2" welded perpendicular.
Brett
   / 30" LED Lightbar install on 5 series cab tractor #20
Thanks for the pics. Looks great.
3PT DRAG HARROW (A52708)
3PT DRAG HARROW...
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
4 WHEEL WAGON GEAR (A52708)
4 WHEEL WAGON GEAR...
Box Truck (A56858)
Box Truck (A56858)
2009 International 5500i T/A Wet Kit Day Cab Truck Tractor (A55973)
2009 International...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
