5' Grain Drill for 6' Tractor?
/ 5' Grain Drill for 6' Tractor? #1
Stickbo
Lake Mills, WI
2008 Kubota MX5100
I am going to take a look at an old grain drill that is 5' wide. But my tractor is 6'. I would be running over a bit of previously planted strips on every pass and the drill won't quite cover my tracks behind me.
I like the idea of the smaller drill for ease of transporting on a trailer, but not sure how that would work out for me. Should I pass on this one and keep looking for a little wider drill?
/ 5' Grain Drill for 6' Tractor? #2
You can transport a grain drill up to 8 ft wide on a hitch or on a trailer without getting into trouble with the law. I'd find one at least 6 ft wide--7 or 8 ft is better.
I restored two Minneapolis Moline P3-6 grain drills (10 ft wide, 20 drops, single disc openers) that I bought for $275.
It's relatively easy to reduce the width of a drill like this to 7 or 8 ft.
Good luck
Thinking about it, I suppose I could just pull the drill with my ATV. I think it would handle a drill that size. I'll be interested to see what kind of shape it is in.
/ 5' Grain Drill for 6' Tractor? #4
Actually you will see better germination in the tracks of the planted ground .
/ 5' Grain Drill for 6' Tractor? #5
Yep, going back to the old cultipacker days. :)
/ 5' Grain Drill for 6' Tractor? #6
Offset the drawbar so that the planter covers one side or the other.
The drill was in good shape for its age and everything works. At $700, I couldn't pass it up, and will easily pull behind my ATV.
/ 5' Grain Drill for 6' Tractor? #8
The drill was in good shape for its age and evening works. At $700, I couldn't pass it up, and will easily pull behind my ATV.
There you are--problem solved.
Good luck.
