Tiller advice on tillers...
/ advice on tillers... #1
gravelman
NH
Kubota 2650
Hi folks...gravelman here..i want to buy a 50 or 54" rototiller for my tractor. i have a Mahindra Max 25... any suggestions?? will not see alot of use but i dont want piece of junk either... thanks
/ advice on tillers... #2
There are a lot of tiller options. Some folks like the reverse rotation type where the dirt is thrown forward by the tines, others like myself like the forward rotation due to rocky soil that would likely hang up a reverse rotation tiller. I think the reverse tines would dig into hard soil a bit better so it is a trade off in what you want to do. Another debatable issue is chain drive versus gear drive. I prefer the gear drive so I don't have to deal with a slack chain or chain tensioner adjustment but that is just my preference. I don't think one does any better than the other in terms of tilling.
The one thing that is not debatable is that one with 6 tines per flange is much better than one with 4 tines per flange.
The top cover on some is pretty thin like my King Kutter II and rocks will put dents in it. Look at this item when selecting a tiller and get one with the thickest steel.
Next check the welded areas. There have been some reports here on TBN of some brands with really crappy welds. I would avoid any brand like that also just because if they try to save a little by improper welding, they likely do the same with other items.
/ advice on tillers... #3
I've been happy with the 72" King Kutter tiller. I cannot recall what the exact sizes are of smaller models but believe they use essentially the same mechanism. Sturdy, gear driven and easy to use.
/ advice on tillers... #4
I do a lot of beach tilling and have had several tillers the best I have had is the sicma tiller it has 6 cutters instead of 4 and has forward rotation it is more expensive but some times you get what you pay for
/ advice on tillers... #5
At 1600 lbs and 20 hp, your tractor will do good with a tiller of any brand that your wallet likes. I think 54" may be on the border line and suggest staying closer to 48"-50". But size depends on the soil, depth and speed. 54" will work but just slower.
/ advice on tillers... #6
Check out the Ansung Terra Force line. They are built strong. Another place to check and this may be a cheaper option depending on your usage is you local agg rental place. If it is in their rental fleet it is a good bet it is dependable. Sometimes you can pick them up on sale too from them.
/ advice on tillers... #7
It's hard to go wrong with the King Cutter (County Line at TSC) brand for durability. I have a 44" model that I use behind my little Ford 1100. The Northern Tool models were cheaper, but the tines did not seem to be as sturdy as the County Line. My only beef is that the unit could stand to be geared lower, i.e. at 540 PTO the tines are spinning like crazy and my little tractor bogs down a bit in our hard clay soil.
Also, I would suggest measuring the actual width of your tractor and get the smallest size tiller that will cover your tracks. It will be easier to control, easier to store, and easier on your hydraulics and engine.
/ advice on tillers... #8
Check out my vid! This is a 72" King Kutter tiller. Good unit!! Powered by a 38 hp Kubota.
https://youtu.be/m38pf-JaU0A
Let me know if you have any questions.
/ advice on tillers... #9
I think your machine is perfectly capable of a 5ft tiller. 50" is on the small size. I have an LS J2023 which is similar in HP to your machine, about 300lbs lighter, and not as wide. I just bought a 5ft King Kutter tiller about a month and my tractor has no problem at all with the 5ft tiller.
The biggest thing you'll notice with a smaller tiller is you will need to offset the tiller to one side or the other in order to cover one of your tire tracks. The a 50" tiller won't be wide enough to cover both. Offsetting is a hassle and if you can get one big enough to keep from having to do that, go for it! But if my tractor will easily operate a 5ft tiller, your tractor should also.
/ advice on tillers... #10
I agree, don't go too big.
/ advice on tillers... #11
King Kutter has been recommended and is a good unit, but don't get one without seeing the unit you are taking home with you first. I have a KK tiller that shipped to me direct from the KK factory, and the paint is the worst paint I've ever seen on a piece of equipment. There wasn't a piece or panel that didn't have runs in the paint running three different directions... There were places the paint would wipe off with a rag. Worst paint ever...
/ advice on tillers... #12
Yeah the paint is not the best. I'm not a fan of KK but I like my tiller. Especially for the price!
/ advice on tillers... #13
And whatever tiller you get, store it out of the weather. My bush hog and box blade are the only implements that get left out in the rain. Too many moving parts on a tiller and I've seen several that were hopelessly rusted out.
/ advice on tillers... #14
Yeah I agree! Too many moving parts to rust up on ya. And if you have a KK it will rust in a few weeks! Hahahaha!
/ advice on tillers... #15
I too have a Sicma tiller. It is 65'' and covers my tire tracks totally. The six tine is the way to go. I've had a Bush Hog brand previously with only 4 tines . This Sicma way out performs my other brand. These tillers are not cheap. Good luck with your choice.
/ advice on tillers... #16
Agreed, I can complain about many things about my KK, but not the operation or price.
/ advice on tillers... #17
My King Kutter must be an annomally. It came with a good paint job, sits out in the weather, and the only thing rusted is the cotter pin that holds the rod that keeps the plate on the back.
It is the 48" Professional model and it is built to naturally offset and cover the right tread. Sometimes I wish I had a bigger model, but when it starts bogging down in wet soil I realize its the right size for my 29 horses. šŸ‰
/ advice on tillers... #18
My 72" King Kutter also sits outside though it has a tarp thrown over it in winter. Doesn't seem any worse for the wear after four seasons. It is gear driven so all the mechanical parts are bathed in oil anyway. The tine tips get rusty but two minutes of tilling fixes that.
/ advice on tillers... #19
I keep my tractors, boat, motorcycle and cars under cover. Everything else sits outside. A little rust just gives it character.
/ advice on tillers... #20
Make sure you keep the gear box vent port covered so no water can work its way into the gear case.
2011 CATERPILLAR 305.5D CR EXCAVATOR (A62129)
2011 CATERPILLAR...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
206707 (A58375)
206707 (A58375)
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
2000 Dodge Ram 1500 4x4 Ext. Cab Pickup Truck (A61568)
2000 Dodge Ram...
2007 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A62129)
2007 CATERPILLAR...
