Recommend me an attatchment to pick up logs(other advice welcome too!)
   / Recommend me an attatchment to pick up logs(other advice welcome too!) #1
Southjersey
Member
South jersey
Mahindra 3016 shuttle
Hi,I had a tree guy take down some huge trees in my yard, now I need to get rid of the wood. I have quite a few 30-36" diameter logs that are 3 foot long that I'm trying to figure out how to move using the least amount of manual labor possible(I have a bad back). So far I've come up with buying a new chainsaw to make them smaller and just loading up my bucket or buying skid steer attatchment for the tractor and lifting them with the pallet forks, or maybe a grapple? Or trying an ad on Craigslist for free firewood. Any ideas?
   / Recommend me an attatchment to pick up logs(other advice welcome too!) #2
Grapple would the slickest option, but free fire wood could be the easiest and cheapest.
   / Recommend me an attatchment to pick up logs(other advice welcome too!) #3
Definitely- you need a grapple.
Might be a stupid question but I'll ask anyway, grapples are capable of picking up logs from the top correct? Kinda like the claw game at amusement parks :D ?
   / Recommend me an attatchment to pick up logs(other advice welcome too!) #5
Yes, they are fully rotating - just like your FEL. They also open/close to grasp.
You'll find grapples in several styles - single lid - double lid - teeth that come together like fingers - teeth that interlace for tighter grasp - lightweight - heavyweight. You can spend a lot - or a relatively little.
Just wanted to make sure they had the clamping strength to pick and hold an approx 4-500 lb. log while I transport it to a lay down area.
   / Recommend me an attatchment to pick up logs(other advice welcome too!) #7
I'm guessing the log in my pic above was 1200 - 1500 lbs. Remember - you will need rear weight to safely lift heavy loads.
   / Recommend me an attatchment to pick up logs(other advice welcome too!) #8
Pallet forks. You can not only move logs and brush, you can move a whole lot of other stuff you can't move with a grapple. You'll suddenly find pallets are your back's best friend, and nearly everything you move will end up on them.
As for logs, center the weight, tilt the forks back, and the log will stay on them just fine. All I've used for nearly 20 years, and I own a sawmill. Only way I'd buy a grapple is if I was in the land clearing business full time.
   / Recommend me an attatchment to pick up logs(other advice welcome too!) #9
Op specified to "pick up from the top." Pallet forks are a great tool as well and I have a set. Funny thing, I've used them one time since I bought the grapple.
One other consideration on the grapple .... you will need a 2nd set of hydraulic ports. My DK50 had an extra set on the rear, so I had hoses made and routed them up front for the grapple.
I asked about from the top because I was trying to avoid ripping up my grass while getting under it but at this point I just want to get this crap cleaned up asap . I've been reading numerous threads on pallet forks and I'm leaning that way , any recommendations other than the EA brand?
2016 New Holland Boomer 47 4WD Front Loader Utility Tractor with Bush Hog BH16-2 (A50322)
2016 New Holland...
100 GAL FUEL TANK (A50854)
100 GAL FUEL TANK...
2013 PETERBILT 367 (A50854)
2013 PETERBILT 367...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2015 FREIGHTLINER...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
