Floor jack not holding under pressure
/ Floor jack not holding under pressure #1
robstaples
Gold Member
Near Ann Abor, Michigan
kubota / L39 TLB, BX2680
My 3 ton floor jack will move its entire range with no load. When I tried to lift my tractor to add chains, it would " slip" and not lift. No oil leakage in its life at least where I stored it. I'm giving it away but thought "working" would be nicer. What is the most common failure for these symptoms ? It's Harbor freight. Probably used 20 times in 10 years.
Thanks in advance
/ Floor jack not holding under pressure #2
My first reflex would be to check the oil level...looks like low oil symptom to me.
/ Floor jack not holding under pressure #4
If it goes all the way up it's not low on oil
if it is creeping down, it is either the main ram cup or a valve.......if it is the release valve (gear under handle) you can reseat it if you tighten by hand, then tap it with a hammer ONCE, then open release valve, pump up a few times and repeat the tap......ONCE. Also another tip is to take off handle (see the small knurled thumb screw not painted) and grease inside the handle socket....sometimes they get rusted and don't tighten up the release valve enough
If that doesn't do the trick then it is either the ram cup, a discharge ball valve, suction ball valve or overload valve.......in which case the dumpster and wallet can fix it easily
the old jacks (before the Asian knockoffs) were able to be rebuilt but one by one they went out of business and parts availability became scarce, jacks became a throwaway commodity
Athey 7-12 Force Feed Loader (A62679)
Athey 7-12 Force...
LOOK! (A63109)
LOOK! (A63109)
2015 Kubota RTVX1100C (A62177)
2015 Kubota...
2016 P.J. Deck Over Trailer, VIN # 4P5F82028G1250354 (A65563)
2016 P.J. Deck...
2017 Hyundai 53' Dry Van Trailer (A62613)
2017 Hyundai 53'...
Case SV280B (A60462)
