3 point lift Ford 5000
/ 3 point lift Ford 5000 #1
Capline
Cooroy Qld
Ford 5000
The 3 point lift on my Ford 5000 is stuck in the raised position. I bought it second hand, and on first use it lifted and will now not lower. I believe I am using the position/draft and selection levers as intended. Any ideas?
/ 3 point lift Ford 5000 #2
Re: 3 point lift
Not sure of your model but most will have a turn knob between your legs at the base of the seat. It controls the drop rate of the 3ph. It could be closed off. Photo of the area could help...
Also, if you added Ford 5000 in the title, you would attract people familiar with your model. (2 cents)
Re: 3 point lift
Teg, good point, will edit title.
/ 3 point lift Ford 5000 #4
You'll find out that you can't edit the title!!! You might be better starting a new thread in the ford section.
Did you find the 3ph drop rate knob? I ask this because there lots of other people that the act of getting on and off the tractor, their foot will repetitively bump that knob until it closes...
Teg, sorry for delay. My model has the FLOW control and SELECT valve on the right hand side of the housing. SELECT is closed (no externals) and FLOW is fully anti clockwise which I believe to be maximum rate. I feel there should be a relief valve that would enable manual lower and hydraulic pressure relief.
/ 3 point lift Ford 5000 #6
If your draft control is fully raised I don't think the lift arms will drop. It's that way on my JD and Kubota. Check that.
Also, you can edit the title. Go into edit and then advance and change away.
If your lift arm problem persists, find Soundguy and ask him. he is Mr. Ford around here and knows what he is talking about.
/ 3 point lift Ford 5000 #7
wow, you changed the title... when did that change :p!!!!
/ 3 point lift Ford 5000 #8
It's been like that forever. Read the post before yours. I change my titles all the time.
/ 3 point lift Ford 5000 #9
Pull the valving in the lift cylinder. You may have apoppet stuck
1999 38ft Beverage Trailer (A65563)
1999 38ft Beverage...
Wagon Wheel End Table (A65583)
Wagon Wheel End...
100 Gallon Plastic Tank (A65640)
100 Gallon Plastic...
Metal Toolboxes (A65583)
Metal Toolboxes...
Craftsmen 3400 PSI Pressure Washer (A65579)
Craftsmen 3400 PSI...
2014 FREIGHTLINER CASCADIA T/A SLEEPER TRUCK TRACTOR (A59914)
2014 FREIGHTLINER...
