Adding Kubota rear remotes
/ Adding Kubota rear remotes #41
Do any of you have 3 rear remotes on your L5030HSTC ? I have 2 now and planning to add the third, got the L8307 and L8304 kits from Ebay, but it looks very cramped in there between the valve end cover and the cab frame. Before I take the wheel and fender off it would be good to know that it will fit...
Br, / Marcus
/ Adding Kubota rear remotes #43
Let me add something for guys with multiple remotes who don't use them a lot. Last year I had some overheating issues on a tractor and after lots of angst and dealer diagnoses, it turned out to be a stuck lever for one of the remotes. It wasn't stuck enough to squeal but was stuck enough to cause a problem. Solution is to make sure your levers are not stuck by giving them a quick push in both directions every now and than.
/ Adding Kubota rear remotes #44
Br, / Marcus
I have the same tractor and also have been thinking seriously of adding that third remote. Be sure to post if you do it.
/ Adding Kubota rear remotes #45
No one with a L5030 HSTC and 3 remotes ?
Not exact same model but I have triple remotes. Here's my install
http://www.tractorbynet.com/forums/...install.html?highlight=Factory+Triple+remotes
Very nice install thread, thanks.
I will post all info in my thread about my L5030 here: http://www.tractorbynet.com/forums/.../327592-just-bought-l5030hstc.html?highlight=
/Marcus
/ Adding Kubota rear remotes #46
Hi guys. Reviving this thread with a question or two.
After you actually got them installed and tested, do either of the Kubota OEM valves (L8303, L8304) have the capability to provide full continuous flow for something like a log splitter? With a detent, or would it have to be mechanically locked in place?
If NOT, has anyone found a valve WITH a detent that will match up to and stack with the Kubota valves (and still fit)?
/ Adding Kubota rear remotes #47
Excellent question. My whole parts list for my model only offers float or double acting. I really wanted a detent option.. Don't like the bungie concept but seems many use it..
/ Adding Kubota rear remotes #48
Good point.. I always flip all 3 back and forth after shutdown to release pressure and try to feel the hoses to make sure there isn't a particularly hot one...
/ Adding Kubota rear remotes #49
Don't know about other models, but the factory stacking valves for my L3200 seem to be made by Husco.
I believe the L3200 had the option of double-acting, double acting with float detent, and double acting with detent for the valves.
/ Adding Kubota rear remotes #50
Have 2 valves on the GL3130 GST. One valve normal second one has up and down with float. The piping for the stacking kits is on the small side and would not want to run extended with the valve held open with bungee cord for splitter because of the heat build up. Have a backhoe loop that is connected between loader and 3 pt hitch which I would feel comfortable using full time but the flow would make the ram on the splitter cycle time too long.
I do have an older Speeco 34 ton splitter with 8HP 2 stage pump putting out 15gpm and none of the medium sized utility tractors come close to that flow.
PTO might give you enough flow for decent speed.
David
David
/ Adding Kubota rear remotes #51
I just added the Kubota remote kit (Valve 1 only) and it was easy.
I only removed the panel in front of the seat (four bolts and the hydro speed knob). I did not remove the wheel or the seat or the tool box and I found access to be very easy. Installation is about an hour +-
I went with the Kubota part and if fit perfect, looks well made, includes EVERYTHING including mounts for the hoses and quick connects for your implement hoses. I have an L3010.
The kit is well priced and worth every penny. I ordered mine from Carver.
Hello Harley Bob, Can you tell me who or where "Carver" is as I would like to price out the entire remote kit?
Thanks, Robbin
(4) Trail Quest 235/80R/16 Tires and Rims (A64047)
(4) Trail Quest...
02GER CHICKET HOUSER 240F (A62131)
02GER CHICKET...
2012 GENIE Z-45/25J ELECTRIC BOOM LIFT (A62129)
2012 GENIE...
EZ-GO Golf Cart (A61166)
EZ-GO Golf Cart...
2019 GENIE S-60XC' TELESCOPIC BOOM LIFT (A62129)
2019 GENIE S-60XC'...
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
