B2400 Alternator
/ B2400 Alternator #1
Gomez
Gold Member
Bucks County, PA
Kubota B2400
my b2400 battery light came on yesterday and I also noticed a faint burning rubber smell. Took the alternator off and tried turning it by hand. It would turn in one direction easier than in the other. Put it back and started it up. Alternator spin for about a minute then seized. Looking online for a replacement, there's a broad range, from $75-$200.
Another thing I came across during my search, I thought these were alternators, not dynamos. I saw one comment stating if the unit spins freely, it's an alternator. If it has a clunking feeling, it's a dynamo. Mine has the clunking feeling when it can turn (like a stepper motor), of about 8 steps per rev. Also, it has 2 wires which to me indicates an alternator.
I'm leary about the low price replacements.
Any thoughts?
Thanks
/ B2400 Alternator #2
Any thoughts?
Thanks
Post a pic I'll tell you immediately what you have. A dynamo is going to look like a solid shell. An alternator will look like what you'd have on your car. More open and vented for cooling. If what you have has two blue or grey wires with bullet connectors it's a dynamo.
Brian
/ B2400 Alternator
Brian,
Thanks, I attached a photo of the unit like on my tractor (except mine is painted).
It's the shell, not vented.
Is it better to replace in-kind or should I get an alternator?
/ B2400 Alternator #4
My battery light is on too (Kubota B2710), have to put the tractor on a charger to be able to start it.
At the battery there is no voltage difference running or not. My dynamo looks same as the 14Amp unit Gomez' posted and it's painted Kubota gray. It has a two wire output, both light blue, with bullet connectors. They were corroded pretty bad but I cleaned them up with hopes that was the problem, but still no charge voltage at the battery. I did not put an voltmeter across them, was busy with other stuff. I intended to test it later but didn't.
Is there a quick dynamo test that I can do to determine whether to order a new unit? Is the output of the dynamo AC or DC and what values are expected?
/ B2400 Alternator #5
I did the alternator upgrade on my 2410 and it was well worth it.
Easy enough to replace- you also get a new mounting bracket and belt. Between that and my battery maintainer, I get many years from my batteries.
/ B2400 Alternator
Does anyone know if this kit is still available?
I saw mention in one discussion group showing it's discontinued.
Adams Weight Hopper (A63688)
Adams Weight...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
New/Unused AGT YSRT14 Mini Skid Steer (A65583)
New/Unused AGT...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2016 JOHN DEERE 323E SKID STEER (A64279)
2016 JOHN DEERE...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2008 Ford F-250...
