Front-End Loader Need Help
/ Need Help #1
coltfireman
Colt, Ar.
5320 JD
This is my first post and hope I'm posting in the correct forum. I have a 2wd 5320 and just recently bought a front end loader for it; I found a deal at least I thought I did. The loader is a Bush Hog 2526QT; the guy I bought it from had it on an 830 JD. The problem is that after I bought it I can't find bracket for this loader that fits my tractor. I know they make them; or have made them. If anyone knows where I can find a bracket; new or used I would appreciate it.
/ Need Help #2
:welcome:
To TBN Mr. Fireman. If anyone can help you, it will be here as these are the most knowledgeable people in the world.
/ Need Help #3
Few find 2-WD tractors and Front End Loaders a satisfactory combination.
You need 4-WD to push loader bucket into piles.
Weight of loader leveraged ahead of front wheels unloads weight on driving rear wheels, so you have minimal traction with bucket filled.
/ Need Help #5
As Egon says, you may have to have a bracket welded up from scratch, I've done that in the past. You do not necessarily need 4WD with a FEL but, absolutely, 4WD is better. Many of us old-timers worked for years - decades - with 2WD and FEL, some (including me) even without power steering. You need lots of rear ballast. You work with what you got.
/ Need Help #6
That lack of power steering builds character! It's hard on thumbs too.
/ Need Help
Appreciate the responses; as far as my tractor being 2wd that is not a problem. I just truck patch, grow tomatoes, watermelons, peas, etc... Not planning on doing any large jobs with a loader just need some help carry post, fertilizer and other needs around the farm. Also I have already talked to a local shop about building a bracket, was hoping to find an original built for my tractor.
Thanks
PREVIEW DATES AND TIMES (A61166)
PREVIEW DATES AND...
6 Row Harrell Stalk Chopper (A62177)
6 Row Harrell...
New/Unused 72in No Till Seed Drill (A61166)
New/Unused 72in No...
17601CFL (A59228)
17601CFL (A59228)
UNUSED RAYTREE RMBD72S - 72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
2017 BX2680 Sub Compact Utility Tractor (A63118)
2017 BX2680 Sub...
