CHIPPERS
/ CHIPPERS #1
MAPLECREST
ALDEN MICHIGAN
NEW HOLLAND TC35
I am looking to select a mechanically driven PTO 8 inch chipper for my New Holland TC35.
I have seen one, painted green, obviously imported but with no manufacturing identification.
It has a control to disengage the log drive and one to lift the feeder roller.
Can anyone identify this chipper.
/ CHIPPERS #2
/ CHIPPERS #4
I think an 8" is going to be too big for your tractor. More like a 4".
/ CHIPPERS #5
I would identify it as something painted to match John Deere.
If you would like advice on selecting a chipper give more details please.
How important is cost?
Will this be used in a business where down time is $$$ or Harry Homeowner where if you need a new belt or knife you can wait a few weeks?
Do you demand perfection or can you put up with solid but ugly welds?
Do you want direct drive or belts?
My 18 PTO HP B7610 could just barely run my 8" Jinma, my 42 PTO HP M4700 ran it like a breeze. I think a 30 PTO HP tractor will run most import 8 inch square throat chippers.
And not all "8 inch chippers" are built to the same "8 inches", if I remember correctly the 8" throat on a chipper is not always 8". For example the Wallenstein "throat" for their BX62S (called a 6" chipper") is 6.5" x 12". It can take a 2x12. My 8" Jinma is 8" x 8", it can't take a 2x12. That rectangular throat could help a lot with typical forked branches etc. On the Jinma chippers the only two differences between the inch model and 8 inch model was the size of the hole cut for the throat and the price, all other parts were the same.
For your listed tractor I think an 8 inch Chinese (Jinma, Value Leader) or Chinese/modified (Woodmax) would work or a 5" Wallenstein or equivalent Wallenstein BX52S 5-inch 3 Point Hitch Wood Chippers - Wallenstein Outdoor Power Equipment Made in Canada.
2017 SANDPIPER 5TH WHEEL RV TRAILER (A60736)
2017 SANDPIPER 5TH...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2019 Chevrolet Cruz Sedan (A60352)
2019 Chevrolet...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
207274 (A52708)
207274 (A52708)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
