kubota engine blocks
/ kubota engine blocks #1
scvfd7241
I was wondering if anyone could tell me what the kubota engine blocks are made of. I have been told that new kubota tractor engines are made of aluminum I am just curious.
/ kubota engine blocks #2
I have not seen an aluminum Kubota block. I'm pretty sure somebody was jerking your chain. To the best of my knowledge they are all cast iron.
Brian
/ kubota engine blocks #3
All of the old ones are cast iron. Aluminum blocks would be more expensive than cast.
/ kubota engine blocks #4
The only aluminum Kubota engine blocks I've seen are the gasoline RTV engines and the lawnmower engines like found on the ZG series.
/ kubota engine blocks #5
Whats the value of an aluminum block in a tractor? In a car the fact they are lighter is a big plus, pretty much a negative in a tractor. Better thermal properties, but not by a huge margin over cast iron. Iron is going to be stronger, more durable & less likely to melt if it overheats badly. Not to mention iron is WAY vheaper than aluminum.
I agree that having an aluminum block in a tractor would be a negative and so does the person who told me they were aluminum. He said he wouldn't but a kubota because they have aluminum blocks. But I can not find anywhere where it states what the blocks are made of to prove him wrong.
/ kubota engine blocks #8
Get him a MAGNET. Then he can check for himself....
These "cow magnets" (see link below) offer the additional advantage of allowing "hands-free storage," for the person alleging Kubota blocks are aluminum.
LINK: https://www.google.com/search?q=cow+magnet&tbm=isch&tbo=u&source=univ&sa=X&ei=gaJAVanYLZPfgwSU0YGQAg&ved=0CDEQsAQ&biw=1231&bih=558
PRO-TIP: When not in use and storing the cow magnet, he should REVERSE the magnet's normal (bovine-specific) insertion instructions.... (Then he will always know where it is, and he can continue to check out his aluminum block theory wherever he rambles). :laughing:
My Hoe
/ kubota engine blocks #9
While aluminum is lighter in weight . . Its ability to absorb heat stress (with typical cylinder sleeves ) should be better than cast iron. Cast iron like concrete is hard but also like concrete . . It is more brittle.
In a diesel I'd think cast iron remains a good choice . . But technically as a pattern of rpms climbing it becomes a different story. Just my 2 cents.
2000 Freightliner FL112 T/A Dump Truck (A61568)
2000 Freightliner...
UNUSED KJ 20' BI PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20' BI...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
New/Unused 7ft Fork Extension (A61166)
New/Unused 7ft...
2023 CATERPILLAR 299D3 XE SKID STEER (A62129)
2023 CATERPILLAR...
2013 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A61568)
2013 International...
