New machine
/ New machine #81
Your dealer doesn't have a match? I found my local do it best hardware stores generic bright red is close, enough for me,
/ New machine #83
Jack, thanks for the post, they have a nice website, I was able to get pricing and pn for some parts I needed.I may order from them..
/ New machine
This is the best part of the year for my Ventrac. I can go from Snow blower to Grass cutter in less than a minute.
/ New machine #85
My snowblower has been idle for about 6 weeks now,but with the spring clean up season here,I've been switching between the slip scoop, mower deck, leaf blower,sweeper, and now the rototiller this week, my ventrac sure has been a valuable tool!
I use it often for moving my trailers around until my yard firms up.
/ New machine #87
I always wondered what was so special about those things!
That is not the only reason they're special there's lots of machines that can be used all year. They have a light footprint and especially combined with dual wheels they have the ability to get into areas that nothing else can, and walk right out.. Same goes with climbing hills and hillsides...
/ New machine
Seems I might have to go back to snow blower.:mad:
/ New machine #89
I notice you have a lawnmower as well - why is that?
/ New machine #91
/ New machine #93
Thank you, my machines are older but fully operational and in good shape, the heavier machine was tearing up a set of stock turf boss tires in 250hrs..that machine is 1850lbs, with my big rear on it 2200 plus..most of it on the rear tires,lots of torque, and 50hp, very hard on tires..the guys who ran these machines on the Dixie forums told me that the carisle field trax HD was the only tire that held up on them...so that's what I'm running. The smaller machine I changed from 22x11x9 to 25x13x9 when it was almost new, simple swap, readjust the deck pitch ..gained almost 2mph, and way better rear ground clearance especially with the bagger, also it goes almost anywhere in the soft grass, not quite as good as a ventrac but amazing for a zero turn ..those tires are good yet and they do ride a little better than the Carlisle. .with the thinner sidewall...
/ New machine #94
Did you say 50 hp on your big mower? On what a 5' deck? What are you cutting?
I switched my mower from the turf tires to the chevrons a couple of years ago . I could not believe the difference in slippage. The chevrons hold hills better and are much more positive ground speed. I find they ride rougher though not smoother. I also find that if you plant them during a turn you do more turf damage. I would never go back though as it is so much easier to run without the slippage.
/ New machine #95
Dixie Chopper 2005 XXWD5000-72 Here's the specs..6 foot 50hp..makes the 31 ventrac feel like a wimp...it has the torque to mow tall grass down easily and brush hog easily .Like the ventrac 950G, the Dixie diesel was killed due to emissions laws..probably the most powerful zero turn ever made, great on fuel and amazing yanmar diesel reliability, I bought one of the last ones they made...i am going to keep it for as long as I can get parts, I'll put it up against any brand new ztr , and it's an 05..
/ New machine #96
Sounds like a awesome tractor. What about the other. Same thing or does it have the 2-23hp motors
/ New machine #97
My other machine is a 25 hp/60" deck, Kohler Command , the diesel machine is a beast ,it's got a few flaws ,the engine runs on the warm side on hot days,and the cut quality isn't quite as good as my 60 inch machine.
/ New machine
Approaching the 200 hour mark, time to change the engine oil with some mobil 1 5w40. What else do you guys do before snowblower time?
/ New machine #99
Here in NY for some reason Mobil 1 is so expensive, I stopped using it about 10 yrs ago,I use Rotella T6,or Chevron Delo 5w40 full synthetic both as good or better than Mobil 1 and both are 20.00 a gallon at Walmart, Mobil 1 is 27.99 a gallon..If grab a bottle of diesel antigel now and start adding it to your fuel around thanksgiving time or so...cheap insurance.
/ New machine
Mast Lepley is picking up my machine on Monday to change out my dash that fogs up, add a horn kit and change all the filters. Still thinking to add a Grammer seat this summer.
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
TANK MANIFOLD (A58216)
2018 Dodge Charger (A61574)
2018 Dodge Charger...
2006 TerraGator 8104 (A63688)
2006 TerraGator...
Engine (A59228)
Engine (A59228)
