Chipper My new Woodmaxx WM-8H wood chipper
   / My new Woodmaxx WM-8H wood chipper #21
Just picked up a WM-8H, and while I've only one day of use on it - I'm pleased so far.
I'm using a Kubota 3130 w/Pat's quick hitch. With the added length of the hitch, the included PTO shaft just barely meets the specs - within 1/4". Also, the top attachment bar had to be flipped from the stock position - that shortens it up by a couple inches, allowing my TNT cylinder to reach it.
I've only sent soft cedar through it so far, but it never slowed down on the fastest setting. I sent numerous good sized trees through it, at or near the max size it could handle. Feed worked without intervention 95% of the time...every once in a while, I had to reposition and/or give a shove on large curved trunks.
Filled up the 8 yard trailer in about an hour.
   / My new Woodmaxx WM-8H wood chipper #22
There is just something awesome about turning a giant pile of brush into a lovely smelling pile of woodchips!
   / My new Woodmaxx WM-8H wood chipper #23
Yeah...a chipper lets you take something apart without having to worry about putting it back together again! One of life's great joys....
1999 JD 4600 MFWD
460 loader
Curtis cab
   / My new Woodmaxx WM-8H wood chipper #24
I placed my order on the evening of April 2nd. I just got the e-mail this afternoon, saying that my new WM-8H has left the warehouse.:cool2: It's been a bit of a wait, but all the reports on these are good.
Katahdin - I assume yours must have shipped as well. I think you placed your order a couple of days ahead of me.
I thought about starting a new thread, but the subject of this old one applies. I plan to post some photos of the assembly process. I must have viewed the assembly video at least 6 times and read the PDF manual 3 or 4 times.:licking:
   / My new Woodmaxx WM-8H wood chipper #25
Mine shipped on the 13th business day. It arrived at the Scarborough terminal early Saturday morning, of course there was no Saturday delivery or pickup. I scheduled the delivery for tomorrow because of the 4 inches of rain we just received. I hope the chipper is delivered early in the morning, I took the day off to put it together and play. :D
   / My new Woodmaxx WM-8H wood chipper #26
Enjoy and be safe!
   / My new Woodmaxx WM-8H wood chipper #27
I must have viewed the assembly video at least 6 times and read the PDF manual 3 or 4 times.:licking:[/QUOTE said:
I did too - but that still didn't prevent me from forgetting to put washers in the correct places in like step 2 or 3!!! Luckily it was an easy fix!! Enjoy!!
Sent from my iPhone using TractorByNet
   / My new Woodmaxx WM-8H wood chipper #28
The delivery truck arrived just before 0800, today is going to be a fun day!
   / My new Woodmaxx WM-8H wood chipper #29
Assembly mission was successful! What a great day!
https://youtu.be/ZqKp4qfgx4M
My notes:
I had to re-do the 2-hole straps that hold on the feeder bin, they are pre-bent, make sure to point them inward, not outward.
I also found a loose bolt going to the "flywheel fan weldment", check over everything carefully. This was not part of the assembly process.
The video differs a little from the actual assembly. The hydraulic control valve is an improved design.
The documentation is very good, and a lot of parts shipped with the correct fasteners already attached and wrapped to the part. That made things a lot easier. Thanks WoodMaxx!
   / My new Woodmaxx WM-8H wood chipper #30
Great Video!:thumbsup:
Thanks for the reminder to check everything over carefully. I was planning to anyway, but you finding a loose bolt gives me extra incentive to take the time to check thoroughly.
I trimmed a few trees in front of the house this afternoon, so I have some brush ready to test mine when I get it. I'm hoping for Friday.
2024 CATERPILLAR 255 SKID STEER (A52707)
2024 CATERPILLAR...
2022 Horizon Trailer (A55973)
2022 Horizon...
2023 Kubota L6060HST Compact Utility Tractor (A56438)
2023 Kubota...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
2017 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2017 CATERPILLAR...
2016 Chevy Silverado Z71 4wd 5.3L V8 (A56438)
2016 Chevy...
