Toyota Tundra Problem?
/ Toyota Tundra Problem? #1
dodge man
Super Star Member
West central Illinois
JD 2025R
While I was working yesterday in a parking lot, I noticed a Toyota Tundra, don't know the exact age, maybe 5 years old or less. It looked very nice on the outside then I looked in the bed. I noticed severe rust. It looked like it was rusting where the cross members hit the bed. It wasn't rusted through but was close, parts of the metal were pushed up a couple of inches and there were about 6 places in the bed that looked this way. I have no idea on mileage or anything but it looked like typical Illinois rust.
Is this a common problem on these trucks? I was mostly surprised because it otherwise was a really clean truck.
/ Toyota Tundra Problem? #2
If you are off on the dates and it is actually a 2000-2006 or so Tundra then the rust problem is well known. I don't know about the bed but Toyota has been very good about replacing the frame and associated parts for free on the affected models (2000-2006 is just my guess). I don't think they have had any problems with the last two versions though.
/ Toyota Tundra Problem? #3
I have a 2006 Tundra and just received a notice to bring my truck in for inspection and replacement if I had any rusted frame components. Mine looks fine.
/ Toyota Tundra Problem? #4
Yup, I own a 2006 Tundra and they did a rustproofing spray on my truck. Mine wasn't bad ... so the frame did not need replaced. Here is a rusty Yota for comparison :) download_20150415_083310.jpeg
/ Toyota Tundra Problem? #6
Yup, I own a 2006 Tundra and they did a rustproofing spray on my truck. Mine wasn't bad ... so the frame did not need replaced. Here is a rusty Yota for comparison :) View attachment 421806
To be fair, that truck is probably 20 years old. Lots of Fords and Chevys with similar severe rust after that long in a northern salt using region.
/ Toyota Tundra Problem? #8
Yup, its a 95. Runs well ... it is eating itself alive, though.
/ Toyota Tundra Problem? #9
My neighbor had the same truck until last year when it failed inspection due to rot. Too bad, it was uber reliable and efficient.
/ Toyota Tundra Problem? #10
I think that one would fail inspection to be honest ... but we dont have them in Ohio. On a side note ... do you like your Kioti? I am looking at one, right now?
/ Toyota Tundra Problem? #11
Love the Kioti. I've had two. The CK20 is a great small tractor that punches above it's weight class. The DK40se HST has been trouble free and a very solid worker for the seven years I have had it. Never been back to a dealer as I do my own routine maintenance and I've been able to fix the few things I've broken by myself. The loader is very powerful and the tractor is easy to maintain (once you get the first HST filter off). I'd buy another in a heart beat. I suspect the NX4510 will also turn out to be a very solid performer though I gather there are a few minor teething problems with the Tier 4 regen cycle stuff. The NX is essentially the same as the DK other than the engine and a few upgrades.
/ Toyota Tundra Problem? #16
I haven't heard of any rust problems for the past 5-6 years.
Here's my 14 model.
Does it look like this? The 12-13 models are similar but the lines are not quite so 'crisp' looking in the older models.
/ Toyota Tundra Problem? #18
I know the '07, '08, and '09 Tundras had issues with the front and rear bumpers rusting through. In the fall of '08 a customer had a 2007 CrewMax and the rear bumper had rotted through in three spots. I have not heard about the bed rust issue before.
/ Toyota Tundra Problem? #19
That rusty one is a 89-94 Toyota pickup. preceded both the Tacoma (roughly the same size) or the "full size" Tundra. (although to be technical at the time 94, there was a truck marketed full size call the T-100 but was "much" smaller than the current Tundra)
The Taco (the small one) was known for rust issues. I have not heard of any issues one the fullsize Tundra.
/ Toyota Tundra Problem? #20
A guy I work with has a'12 Tundra that is rusting around a 4 side windows. Toyota told him too bad. Body shops said that there doesn't appear to be much if any primer or clear in that section of the truck. Even the bodyshops said to complain about it.
2013 KENWORTH T370 DUMP TRUCK (A65054)
2013 KENWORTH T370...
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
1985 Ford Ltl9000 Tender Truck (A63688)
1985 Ford Ltl9000...
2018 International DuraStar 4300 26ft. Box Truck (A61573)
2018 International...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
