Titan 6 ft. Backhoe
/ Titan 6 ft. Backhoe #1
Lutzy48
Member
Miles City, MT
Ford 1710
Does anyone have any experience with Titan's 6 ft. 3 PTH backhoe system. I would like to get a backhoe for my Ford 1710 tractor and don't want to spend a fortune for no more than I would use it. My property is quite remote and I don't want to get into renting one.
The ansung is twice the money of the Titan. I also don't need the pump.
/ Titan 6 ft. Backhoe #4
I think 2X is a bit generous, the 6' Ansung is $3895 shipped vs 2735... 140% vs 200%... but I was simply throwing another option out there which I believe still has a GREAT price point but higher quality. The Titan also includes a hydraulic thumb, which is a fairly $ option. The Ansung is a bit lighter but to me looks better engineered. The Ansung is a common design and used on some production tractors, from what I understand. If you look at the construction, the overall geometry and engineering seems more applicable to actual hoes than a home-built unit... like the tapered stick on the Ansung looks much better engineered and heavier duty versus the rectangular tube steel on the Titan.
On the really cheap Chinese backhoes, I've heard hydraulic fluid contamination can be an issue, so even though I have hydraulics on my tractor (of course), the PTO pump seemed like a better option.
Either route, don't forget the costs associated with building a subframe... I would not operate a 3-point backhoe without one.
Hopefully some Titan backhoe owners will chime in!
/ Titan 6 ft. Backhoe #5
I bought a 3 pt. 6 foot backhoe from Liberty Implements this past summer. I was surprised at the quality and did quite a bit of work with it and no problems. You can google, they have a nice website.
/ Titan 6 ft. Backhoe #6
"Hey Lutzy48,
I just ran across this thread and was wondering if you ended up ordering the backhoe? Like ishiboo, I was hoping some of our backhoe owners would have chimed in as well. We have a lot of them out there “in the trenches” working every day. If you or any other users have questions or suggestions about the backhoe we always appreciate the feedback."
Link: 6' ft 3 Point Backhoe with Thumb back hoe cat 1 tractor excavator TBN BACKHOE.jpg
Craig
1-800-605-8241
/ Titan 6 ft. Backhoe #9
We currently do not offer a sub-frame. Our backhoe is compatible with sub-frames for people that still want to use a frame however, The hydraulic outriggers on our backhoe were developed to provide stability, so the backhoe does not require a sub-frame.
Craig
1-800-605-8241
Craig, I'm looking for a BH... The price on the Titan BK215 and 7' BH's is very attractive, but I can't find any bucket or dipperstick forces listed... Just wondering if you could provide them so I can see how they compares to the other options...
Thanks!
Chris
/ Titan 6 ft. Backhoe #10
Just an FYI, I got bucket and dipperstick forces for the BK215 from Titan. (They sent me the manual) Bucket force 2592lbs, dipperstick force 1975lbs. Lowest of the hoes I have data on. (Titan, are you listening? The BH looks structurally sound, get the supplier to use slightly larger cylinders and get these numbers up!)
I have a spreadsheet of backhoe choices, and the BK215 is actually a couple hundred pounds lower for both forces than the FHM backhoe, commonly available on Ebay. I suppose the dipperstick numbers don't vary by a whole lot, but bucket forces range quite a bit.
(Click the tiny image below to see it bigger)
Also worth noting that the Branson backhoe is made by Ansung, and very likely just painted different. Branson must be using slightly more pressure to it, or measuring differently. I included it because that's the hoe I could get locally...
It appears to me that bang for the buck, Woodmaxx is probably a good choice. Their price does include the pump and tank, so if they come out with a version that runs off the tractor, it should be cheaper...
/ Titan 6 ft. Backhoe #11
Thank you !! Very informative. I'm currently looking for people's experience with these type of backhoes and hopefully more actual users will come out of the woodwork with opinions.
/ Titan 6 ft. Backhoe #12
FWIW, I ended up finding an even better option, at least for me... I found a used Bradco 609, originally set up for a New Holland skid steer. I paid 2500 for the BH, unbolted the NH mounts, and made a 4-point mounting subframe based on Bradco's design for other tractors.
You can actually buy mounts from Bradco for a lot of tractors, just not mine... All Bradco BH's use a similar mounting pattern, so they pretty much all interchange.
The 509/609/511/611 backhoe series are really strong compared to CUT BH's from anyone else... if you have a 40hp+ tractor, I believe they work out well. Mine has a 24" bucket, and it will pluck out a full scoop of wet clay no problem.
I was told it would be slow, but it isn't. My tractor is rated at 11.5gpm, but I only run it at about 1500RPM when using the BH. Faster than that is difficult to control, and generally too fast. I'd imagine that most tractors would need to run closer to 2000RPM to get the same speed, but most newer tractors need to run that fast anyway.
I made a thread about it here... http://www.tractorbynet.com/forums/build-yourself/373738-4pt-mount-bradco-609-mf.html
/ Titan 6 ft. Backhoe #13
Awesome. I'm heading out to see the new tractor models and compare how I feel in them. I'll be buying today or tomorrow but have time to buy the BH so when I get back I'll check out your link. Thanks !
/ Titan 6 ft. Backhoe #14
Is Titan still in business?
Late last night I googled "backhoe attachments" and found a Titan ad for a BK215 with a sale price of $3169.00.
This morning when I looked at ad again to call about it the price went up to $3669.00.
I tried to call all day to get more info and all I got was voice mail.
I sent an email, got response- will reply shortly but never heard from them.
Was that an inventory close out sale and they were all gone???
PATRIOT S/A CATTLE FEEDER (A63291)
PATRIOT S/A CATTLE...
UNUSED IRLMC DELUXE MASSAGE CHAIR (A64281)
UNUSED IRLMC...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2004 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2004 Ford F-250...
DYNAPAC CC524HF DOUBLE DRUM ROLLER (A64279)
DYNAPAC CC524HF...
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A59911)
2001 FREIGHTLINER...
