Newbie trying to pick the right LS for our needs
   / Newbie trying to pick the right LS for our needs
Just for some consideration. Maybe consider a roll over box blade. This way you don't have to stop and get off the tractor every time you may need the rippers. At 800lb or 850lbs, this will definitely get some work done for you and considerably less $$$ than a unit that has hydraulic actuated rippers. ;)
Hehe. I read one of your threads about the Gannon rollover blade. Can I still push and pull dirt with a Gannon versus a traditional box blade?
   / Newbie trying to pick the right LS for our needs #62
You tell me. I brushed a couple of acres and filled a few gullies that day. Most all of it done in reverse. People advise against this, but I think as long as your hitch is stout enough, no problems. Mine sure does work well in this fashion. :thumbsup:
UNUSED SDLANCH SDLGC ELECTRIC GOLFCART (A54756)
UNUSED SDLANCH...
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A56129)
2022 MACK GRANITE...
2019 FORD F-250 XL CREW CAB SERVICE TRUCK (A54756)
2019 FORD F-250 XL...
2014 Dodge Charger Sedan (A55758)
2014 Dodge Charger...
UNUSED LANDHONOR 11' X 19' ALL-STEEL CARPORT (A54757)
UNUSED LANDHONOR...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
