What's in your Oil Can?
   / What's in your Oil Can? #11
I just use up whatever the last remnant from an oil change left me. Have been known to cut it with a little ATF before too. Seems like I go thru more to cool drill bits than anything else.
   / What's in your Oil Can? #12
Tapmatic #1 Gold cutting fluid in the pump oil can that I can reach from the drill press and tap & die sets.
A tiny (8 oz) brush can of Fluid Film in the cup holder of the L series tractor.
I'll have to see if I can cut the Fluid Film with something to get it to flow easily from the pump oil can I keep near the tractors.
Fluid Film is liquid lanolin. You can cut it with isopropyl alcohol, but it needs to be 91% or more (99% is better). The problem is that you have to shake/mix it pretty much every time you use it. Most folks use a 6-to-1 ratio (roughly) alcohol to lanolin if they want it to work through a spray bottle. It's actually a commonly used case lubricant for folks reloading ammunition....so they mix it up and use it in a spray bottle to put a light coat on many cases at a time.
For your use, you could probably use less alcohol...just get it to the consistency you want.
   / What's in your Oil Can? #14
I have leftover motor oil in one, air tool oil in the other.
   / What's in your Oil Can? #15
What do you think of this oil can?
Sweet hey :D
I usually just use clean motor oil
   / What's in your Oil Can? #16
Thanks, Gman - I'll give that a try.
View attachment 421337View attachment 421338View attachment 421339
Sweet hey :D
Sweet!
They really don't make them like that anymore.
   / What's in your Oil Can? #18
Mine is a mix of hyd and motor oil. Whatever is left in the bottles from changing the oil. I'm not fussy.
   / What's in your Oil Can? #19
Drip oil. Whenever I empty an oil container, I let it drip into my drip oil collector, then use it to fill my oil cans. :thumbsup:
   / What's in your Oil Can? #20
Got the normal assortment of spray cans plus a few pumpers, one has used engine oil mixed with a bit of diesel for penetration, another has non detergent engine oil for clean lubrication.
Up here Fluid Film comes in a spray can similar to WD40...Never seen the thick stuff.
Quick Attach 80" Rock Screening Bucket (A50514)
Quick Attach 80"...
2024 AGT INDUSTRIAL QHT-500FL CONCRETE BUGGY (A51242)
2024 AGT...
2019 FORD F450 TOW TRUCK (A51222)
2019 FORD F450 TOW...
2017 Ford F-250 Knapheide Enclosed Service Truck (A50323)
2017 Ford F-250...
E-Z Trail 680 Head Cart (A50514)
E-Z Trail 680 Head...
2006 BOBCAT S130 SKID STEER (A51222)
2006 BOBCAT S130...
