What's in your Oil Can?
   / What's in your Oil Can? #11
I just use up whatever the last remnant from an oil change left me. Have been known to cut it with a little ATF before too. Seems like I go thru more to cool drill bits than anything else.
   / What's in your Oil Can? #12
Tapmatic #1 Gold cutting fluid in the pump oil can that I can reach from the drill press and tap & die sets.
A tiny (8 oz) brush can of Fluid Film in the cup holder of the L series tractor.
I'll have to see if I can cut the Fluid Film with something to get it to flow easily from the pump oil can I keep near the tractors.
Fluid Film is liquid lanolin. You can cut it with isopropyl alcohol, but it needs to be 91% or more (99% is better). The problem is that you have to shake/mix it pretty much every time you use it. Most folks use a 6-to-1 ratio (roughly) alcohol to lanolin if they want it to work through a spray bottle. It's actually a commonly used case lubricant for folks reloading ammunition....so they mix it up and use it in a spray bottle to put a light coat on many cases at a time.
For your use, you could probably use less alcohol...just get it to the consistency you want.
   / What's in your Oil Can? #14
I have leftover motor oil in one, air tool oil in the other.
   / What's in your Oil Can? #15
What do you think of this oil can?
Sweet hey :D
I usually just use clean motor oil
   / What's in your Oil Can? #16
Thanks, Gman - I'll give that a try.
View attachment 421337View attachment 421338View attachment 421339
Sweet hey :D
Sweet!
They really don't make them like that anymore.
   / What's in your Oil Can? #18
Mine is a mix of hyd and motor oil. Whatever is left in the bottles from changing the oil. I'm not fussy.
   / What's in your Oil Can? #19
Drip oil. Whenever I empty an oil container, I let it drip into my drip oil collector, then use it to fill my oil cans. :thumbsup:
   / What's in your Oil Can? #20
Got the normal assortment of spray cans plus a few pumpers, one has used engine oil mixed with a bit of diesel for penetration, another has non detergent engine oil for clean lubrication.
Up here Fluid Film comes in a spray can similar to WD40...Never seen the thick stuff.
Quick Attach Accumulator Grapple (A50514)
Quick Attach...
2015 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A52141)
2015 INTERNATIONAL...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
Westendorf Gravity Wagon (A50514)
Westendorf Gravity...
2015 GMC Arcadia SUV (A50324)
2015 GMC Arcadia...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A52128)
2-Row Peanut...
