Here is anoyher dumb one...
/ Here is anoyher dumb one... #21
I got a used 55 gallon plastic barrel for $15 and a 12v transfer pump from harbor freight for $75 and some PVC pipe and fittings. I put the barrel in the back of the truck and drive it to the gas station to fill. I use the tractor loader to get it out of the truck. It fills the tractor well and lasts most of the mowing season.
/ Here is anoyher dumb one... #22
We tried to fill a non approved barrel and were turned away... actually shut the pump off...
I guess it must vary from place to place.
My service truck has a 34 gallon tank and I installed a pump with a fuel rated diverter valve... it is great for things like tillers, ride on mowers and I never have to carry gas in cans...
/ Here is anoyher dumb one... #23
Go at night and pay at the pump.
/ Here is anoyher dumb one... #24
Just will have to be quick... all stations have attendants.
/ Here is anoyher dumb one... #26
Well the fact that I "Semi Retired" 2 years ago and now only work 45-60 hours a week, I only get about 10 hours a week of tractor time. With an 11 gallon fuel tank, that will last me over a month. So I am going to get another 14 gallon caddy and use the FEL. That makes the most sense for me. I do feel stupid for not thinking of that myself, and Thank you guys for suggesting it. I will have to put a longer hose on the caddy to make it reach, but even I can work a hose clamp. :thumbsup:
Kids got me the same caddy for Christmas. I slip the forks on, slide the handle over the right side fork and lift. Original hose is plenty long when the caddy is dangling under the forks.
/ Here is anoyher dumb one... #27
I would like to know more about your setup. My truck also has a large tank and my gas cans never seem to be full when I need it.
/ Here is anoyher dumb one... #28
Service truck is a 1985 Chevrolet gasoline powered van.
I added an inline electric fuel pump and a 3-way off the shelf fuel valve just behind the front bumper and it's attached to a coiled 3/8 fuel line stored behind the license plate which is hinged.
It would take awhile to transfer a lot of fuel... just perfect for the small amounts needed for mowers, tillers, edgers or to make gallon mixes of 2 cycle.
The reason I decided to do this is because having a van whatever I carry is ALWAYS INSIDE and sometimes even the best fuel cans will have a few drops spilled and smell of gasoline on a hot day was objectionable.
It's been set up like this for 25 years...
Anyone remember the GM cars from the 80's with the gas filler behind the real license plate?
I bought one of these spring hinged brackets and mounted it on the front bumper.
Standard procedure for me is turn on the pump, switch the diverter, pull out the fuel line and turn on the 1/4 turn ball valve at the end and start filling... when nearing full I switch the diverter from hose back to the carb and then let whatever residual drip out from the hose...
This way there is no gas in the line or at the front of the truck except when fueling a can and equipment...
Still get some strange looks from passers by when I using it...
/ Here is anoyher dumb one... #30
So far have not heard back... must be busy.
No rush... was looking to see if they had a dealer in my area.
/ Here is anoyher dumb one... #31
I also use a 55 gallon barrel. But to fill it, I take a few portable (2.5 gallon to 5 gallon) containers to the co-op and fill them with diesel. Then dump them into my barrel. Yeah...I know it is an extra step, but taking an afternoon to make a couple runs to the co-op and fill the barrel sets me up for most of the summer. And the right funnel makes that job easier...
/ Here is anoyher dumb one... #33
IF my furnace oil tank is too low for the hand pump to lift it, then I use a jiggle siphon. I just put a rag on the hood and swing the jerry can (it only has 4 gallons in it) onto the hood and a few strokes with the jiggle siphon and wait. I fill my three jerry cans right after I get a fill up of the HHO.
Silverline Jiggle Siphon 2m: Amazon.ca: Tools & Home Improvement
Bear Statue (A64557)
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
Swict 78in Bucket Skid Steer Attachment (A64553)
Swict 78in Bucket...
2018 Ford Escape SE SUV (A64557)
2018 Ford Escape...
VERMEER FT 100 FORESTRY MULCHER (A65053)
VERMEER FT 100...
2019 CATERPILLAR 336 EXCAVATOR (A65053)
2019 CATERPILLAR...
