Traction Traction in Mud
/ Traction in Mud #1
cmcramer
Member
Oswego, NY
none
Another new owner question?.maybe a tough question to answer? maybe I just need a little hand-holding: I would really like to drive back into my woodlot to haul out some sugar maple bolts for shiitake mushroom cultivation? time sensitive task?.but the é¼*ogging trail is still quite wet. What would tell you more experienced Owners that your L series 4wd FEL Kubota is bogging down to the point where it might get stuck? How deep a tire rut would make you turn back? Would you attempt the trip in 4wd higher gear with lots of throttle, or 4wd lower gear lots of throttle? If I get this beauty stuck?I値l never forgive myself 
Thanks!
/ Traction in Mud #2
Any time the ground is getting close to the underside of your tractor you are getting close to high centering.
A lot of throttle can work against you if the firm ground under the mud is deeper than your ground clearance. The tires will dig down and get you stuck.
Each muddy area is a little different. Depends on the soil and amount of moisture.
You can feel when the tractor is starting to get stuck. That is the time to back out.
/ Traction in Mud #3
I would walk the area with a pointed stick and see how easily it pushes in and at what point it stops, if you get anywhere near 10" I would wait for it to dry out. A L series has decent clearance but high centering is going to be a fun job to get unstuck. Are there any hills to deal with? Do you have R-1's or turf tires? that alone will make a HUGE difference in when to stop. turfs will slick over with mud very easily where R-1's will dig till your belly stops.
/ Traction in Mud #4
If you set up your tractor with duals and wider front tires like this you will never get stuck. If you want to know how I attach the duals I can post more pictures.
I also am better at modifying my tractor than making pictures rotate to the proper orientation. I need to learn how to do that but that is a job for another day.
/ Traction in Mud #5
CM,
Depending on the amount of mud involved and if you are handy with a chain saw, why not construct what the loggers call a "corduroy road?" Place a series of logs perpendicular to the road so you don't sink in the mud.
/ Traction in Mud #6
In my case it's easy to be brave when you have a skidding winch (aka "pull me out of this hole" winch) on the back as plan B, but...some tips might be:
Have your differential locked.
Speed is a your friend as it contributes to momentum to get you through a spot, (or deeper into it before you get stuck) but....
The name of the game is to keep your tires "hooked up" to propel your tractor forward, instead of spinning and digging a deeper hole under it. The idea is to keep tire speed matched with forward tractor speed (i.e. keeping the "ground" under your tires stationary and the tractor mobile) and only applying as much torque as the soil can take.
Soil (mud) can only hold so much force/area (pound/sq. ft) and remain stationary to propel the tire forward before it gives way and gets shot out the back as your tires dig a hole and you are no longer going forward. The key is to find this balance of speed and torque being applied to the soil to keep your tires hooked up as much as possible. Backing off the throttle and reducing speed/torque to keep the tires hooked up can sometimes help. But then you can run out of momentum and power. Catch 22.
When to turn back?: About 15' before you realize you should of.
Well, that's my 2 cents anyways. Easier said than done.
/ Traction in Mud
Very interesting and helpful responses - thanks.
No hills. Just two, scary. 50 foot wet holes in a 1/4 mile trail.
Yep, I have Ag tires.
And no, a log road is not practical for my situation...but a good idea.
Engage differential lock- great tip.
CobyRupert - excellent analysis...I'm still visualizing and thinkin'....seems to me that erring on the speed side over the torque side is the way to go.
Good couple of drying days here in Upstate NY...so maybe this weekend....If I get the nerve.
/ Traction in Mud #8
If you keep moving you won't get stuck.
Bruce
/ Traction in Mud #9
The good news is you said it is mostly flat. That will go a long way in preventing you getting trapped at the bottom of a hill. When you are going forward and if the tires start to spin, use your bucket to push yourself backward out of the slop. When you regain your footing, go home and wait for drier conditions. If the bucket won't find bottom get something to throw down under it to push against. You have got to get those front wheel anchors up out of the mud. Again if you escape, go home.
/ Traction in Mud
So, the differential pedal is supposed to 'lock' in the down position? I was in 4wd, high range, 1st gear with throttle at PTO speed......traveling straight on flat ground.....differential pedal depressed, but sure did not stay down. Did I engage it incorrectly?
/ Traction in Mud #12
Some tractors are designed so that to keep the differential lock engaged you need to keep you foot on the diff lock pedal. Others are designed so that a short tap on one brake pedal will disengage the diff lock.
/ Traction in Mud #13
One thing for sure;you are going to make a big mess.We are just north of you in St.Lawrence co. and are staying out of the woods with our tractors.
I took a ride today on my Rhino,the higher ground was ok for that but would have made a real mess with either tractor.
You should have done your work when the ground was still frozen;then again you probably had too much snow..........If you venture out;make provisions to be rescued.
/ Traction in Mud #14
Two times to to never get stuck! Just before lunch and just before quitting time.
/ Traction in Mud #15
Some say to use 2 wheel drive until you get stuck and then you have 4WD to get you out, then if that doesn't work you have the differential lock as a third option. If you have a front end loader or backhoe that is your last option to push you out. I have been to that point a few times and still managed to get out on my own.
/ Traction in Mud #16
If you had some of these, mud would be fun
/ Traction in Mud #17
The pedal doesn't lock down on all models But the pin that locks the diff usually remains in position until the diff lock load is released. (such as when taping the brakes)
/ Traction in Mud #19
Looks almost like they are hinged to be able to fold them in toward the rim when not needed. Looks like if that's the case it'd be like one heckuva set of "James Bond" spikes.
/ Traction in Mud #20
My experience, if the front tires sink in half way...to axle...then that's too far. The ruts make a barrier that is too high to climb over. Might be a good time to brush up on using the FEL to walk out of a stuck situation. Or, to invest in a winch. I assume you have sufficient chains/tow straps already. Warning...the more times you successfully get in and out the worse the ruts get and the greater risk of getting stuck the next time in. If you haven't found a buddy with a tractor to come watch the fun...might be a good time to find one!
Let us know how it goes! Consider it educational...worst case, leave it there until it is dry then drive it out...
1999 Ford F-150 4x4 Pickup Truck (A59230)
1999 Ford F-150...
2002 POLAR TANK (A60736)
2002 POLAR TANK...
SKIDDED PLAIN/WASTE WATER TANK (A60736)
SKIDDED...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
INGERSOLL RAND  G25 GENERATOR (A60736)
INGERSOLL RAND...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
