mower engaging switch z920a
/ mower engaging switch z920a #1
stumpeater55
ar.
4520 jd 2005
I have a 3 yr old zero turn jd mower. have had orginal switch that engagesthe mower replaced and now after warranty has expired the second switch is going out . was wondering if anyone has replaced the switch themselves. seems fairly easy to get the main side shroud covering off except the height adjustment knob. not sure how it comes off to get the shroud covering off to replace the switch. also what is the cost of the switch? jd z920 A model . any info would be appreciated. thanks
figured it out on switch
went to jd dealer and bought switch 20.00, ask mechanic how to install switch . take out 3 star scews on top of cover and 1 bolt on inside of panel. console comes out exposing switch. depress clips and remove switch pull apart connection and reconnect new switch. not difficult at all. saved service bill
