tractor air seat
/ tractor air seat #1
ihuntbear
Gold Member
new brunswick, canada
2015 tym T554 and 1999 Kobota m4700
Hi All...
Anybody ever make their own air suspension seat for their tractor...i see a lot of them for sale but way to much money..the cheapest i could find was 465.00 dollars and that was just for the suspension...seat and suspension was a little over 1000.00 dollars...I've seen one ,the only things that were different was it had a small compressor and an air bag....with all the knowledge here just wondering if anybody made there own for a lot less $$$$...for the compressor could use a small 12 volt one that plugs into the cigarette lighter to pump up tires but could be hard wired with an on off switch..purge valve on the air line for adjusting the ride..air bag and fittings from a parts store....just wondering if anybody tried yet
/ tractor air seat #2
Make it easy on your self. Just get a small tire inner tube. Set it on your current seat and inflate until comfy....:)
/ tractor air seat
I seen that on a small lawn tractor but I have a 55 hp
/ tractor air seat #4
Not air but I did replace the fixed (non suspension) seat on my Mahindra 2615 with a spring suspension seat from TSC for about $100.
It made a world of difference in ride comfort.
/ tractor air seat
I have spring suspension seat now but the seat is only good for 250 lbs..I'm 275 lbs and hits bottom when I hit a bump in the road
/ tractor air seat #6
I read the other day where another member wedged tennis balls under his seat, kept it from bottoming out. I haven't done it yet, but plan to.
/ tractor air seat #7
The TSC suspension seats only have a 265# spring rating. I should have mentioned that being only 210 myself it worked for me. There are many others air and spring seats I see on line that will hold 350 lb. but don't see prices.
/ tractor air seat #8
Its amazing what TBN members can come up with! I am impressed!
/ tractor air seat
I think there is more knowledge here then putting tennis balls or tire tubes under the seat..
/ tractor air seat #10
Oh no doubt! But if I can convince my border collie to part with a few of her tennis balls, and it solves my problem - I think I might have the last laugh.....just sayin!
/ tractor air seat #11
I've got a base out of a semi truck I plan on changing out the spring bottom one day on mine and using a small 12 volt compressor to run it.
/ tractor air seat
Would it be to high or are they the same height...reason I ask I know where there is one for sale but haven't got there to measure it up
/ tractor air seat #13
Mine is out of a frieghtliner fl business class , and from what I've looked at mine the unit will be fine. But I'd say you will just have to do some measuring to see if the one you found will work for your application , sorry for not being able to help much.
Wooden Glider Chair (A64557)
Wooden Glider...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
GEN POWER 40KW GENERATOR (A64278)
GEN POWER 40KW...
2014 BMW 435i Convertible Coupe (A64557)
2014 BMW 435i...
2019 JOHN DEERE 325G SKID STEER (A65053)
2019 JOHN DEERE...
S/A Solar Towable Speed Trailer (A64194)
S/A Solar Towable...
