Straighten a trailer axle
/ Straighten a trailer axle #1
MESSMAKER
Bluegrass,KY
DK4710SE
I noticed that one of my wheels on my trailer is suffering from a bit of toe out. I suspect I hit a culvert or something. My friend said he had you can bend the axle pretty easily with a chain and a jack, but has never done it. Anyone have any experience with this. I am interested in giving it a try before I buy a new axle.
/ Straighten a trailer axle #2
Personally I would take it to a truck and trailer shop. They have hydraulic rams mounted to a frame for straightening trailers much like a frame straightener at a body shop. I get trailers aligned for $80 a axle at mine.
Chris
$80 would be a no-brainer. I am not sure they will do it that cheap around here. Only a few body shops left and they don't seem interested in smaller jobs.
/ Straighten a trailer axle #4
I would buy the axle. A little off and you spend the $$$$ in tires.
/ Straighten a trailer axle #5
I have done it with the chain / jack method. Not very precise. I prefer to use a press. The last one I did was with my D3 cat, crude but it worked. I have over 5000 miles on it with normal tire wear. Lots of measuring and time. CJ
/ Straighten a trailer axle #6
Price a new axle , depending on the size =they arent that bad , what you save in time is worth it
/ Straighten a trailer axle #7
No experience on axles, but saved these just in case. :D
I got a bit more info. Chain from end to end fastened to the axle and a floor jack in the middle and crank on it until everything lines up. Does not sound too hard.
/ Straighten a trailer axle #9
You need to find out where it is bent first.
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
40in. Skeleton Bucket Excavator Attachment (A61567)
40in. Skeleton...
2020 Ford Explorer AWD SUV (A61574)
2020 Ford Explorer...
2022 TAKEUCHI TB216 EXCAVATOR (A64279)
2022 TAKEUCHI...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
