Buying Advice 1758 Review
/ 1758 Review
/ 1758 Review #22
Cool vids ...
So how are you feeling about the HST now that you've done a but more with it?
/ 1758 Review
For the work in these videos I would not want it any other way, roading with a wood trailer the geared shuttle would have been nice but I made the right choice. These tractors can lift.
/ 1758 Review #24
Glad to hear that.
Yeah you're right, they definitely exceed specs and lift much more than their rating.
/ 1758 Review
More on the Massey for those looking at the 1700 series,,
I now have 23 hours on the tractor, at 20 hours the soot level bar graph went to 2. If every 10 hours I gain a bar then regen will take place around 50-60 or 5-6 bars.
I drove the machine 20 miles today for wood. 10 miles each way and It was a good way to get some time in it. We are muddy and soft with temps around 50 after a low of 30. Can still get in the woods on my federal wood permit early when things are still firm early. Don't think the loggers will get all their piled wood out though.
A couple of things I have noticed is that the Massey has no valve stem protection on the wheels like the Kioti and Bobcat does. I could maintain about 20 mph with empty trailer on the flat if I wanted to but the tractor seems to ride rough and I slow down to about 14-15 at around 2200 rpm. The seat feels; after sitting in it quite awhile today; as though it is slightly tilted forward. I never noticed this before and have adjusted the seat for my 6'3" height. I could have used a tad more cab room. Side windows when open/ one needs to be careful in the woods. You could bust one on a tree as they clear the fenders by some. Fuel consumption today is hard to judge but this unit has a 15 gallon tank and I would venture I used more than the Massey 2615 or the Case IH 55a would have. Roading a heavy load on the flats the HST in high pulled better than I thought. I slowed down some since my loader was full of wood. I did maybe 10-12 mph loaded and the only decent hill I had the tractor would not make the grade at 2500 RPM in high. The geared variants I have owned would have gone up no problem. HST trans still doesn't shift like I want it too. I need to tap pedals and fiddle faddle around sometimes to get a range from neutral. When I am in a hurry this bothers me. I had issues last night getting my 3rd function hoses connected for my Bobcat snow blade. There is no pressure relief valve on the system. Try as I might with the joystick to relieve pressure and turning the engine off and dumping the valves I still had to break the fittings lose on the snow blade in order to get the implement attached. I feel this is more a tractor issue than the snow blade issue since two different skid steers never required this procedure ever.
Windshield wiper at top of its coverage arc is right at my eye level. Maybe midgets were supposed to drive these things. Ran the A/C a little as I was overheating from wood cutting. Very nice and very cool.
HST trans in the woods and cut over super nice to creep and crawl around roots and sharp saplings cut off from the logging equipment. Despite the few limitations compared to a gears trans, the advantages for at least me give it the nod of approval.
The sheet metal on the lower part of the hood closest to the glass on the cab can vibrate and jiggle some when going over a series of bumps or having a specific harmonic with a RPM setting. Not a big deal just thought it could have been more rigid or reinforced at that location.
I ran most of the day in 2WD and I am certain that if the tires were not loaded I would have been required to lock it in for the work I did. Roading on the snow with my load I was in 2WD..
The steps up into cab are strong and stout. I weight #230,. The Kubotas I have looked at flexed at this location on every model I observed.
Overall happy with it and the few squawk will be discussed with dealer.
Wood Dump, digging this loader and the feel of the joystick/location
/ 1758 Review
High range stopped and shifted to Medium on hill
/ 1758 Review #27
Good review again...
I'm assuming you burn thru more fuel because of the nature of HST, running higher RPM than gear. Regarding the Shift-lever being "sticky" ... I still notice that at times, and I'm around 425 hrs I believe. Usually it's just a tap of the pedals and she slips into range. It's something that I have grown accustomed to and hardly notice any more.
I'm wondering if the pressure on your front remotes is part of your dealer installed 3rd function. Maybe a check valve in the diverter keeps fluid in the system. Is it electronically controlled? Maybe with the key in the "acc" position, you can activate the valve and try to relieve pressure that way. I have to remember to do that when I use my electronic diverter on my rears, for my stump grinder. If I don't remember to relieve the pressure before I remove & park the grinder, I have to manually relieve the pressure with a hammer and a cloth. Pain in the azz and not the tractor or diverter's fault ... dumb user in that case.
Nice pics. Looks like that loader is working out after all. I wish you lived closer, it would be fun to put the loaders side by side on my pull scale, both for curl & lift force, to see if the new one is stronger or weaker at any given point.
Did they ever get the manual to you?
/ 1758 Review
Waiting on manual and cutting edge for loader will shoot you the info, so based on my description of the HST performance and the load I had, and the tires loaded, would you say the tractor is running to spec?
/ 1758 Review #29
... so based on my description of the HST performance and the load I had, and the tires loaded, would you say the tractor is running to spec?
Yeah I would say so. I always try to plow snow in H for example. Flat ground, downhill, no problem. I can keep speed up around 15-16 mph. Uphill, I bleed speed until I'm around 9-10, then switch to M if necessary.
I'm in M probably 90% of the time. In fact, I don't think I use it for anything in the warm months besides road travel, or grooming gravel roads at "high speed" (for a tractor LOL) with a landscape rake.
Now, I'm assuming there's a slight difference between our tractors because of the higher HP, and the added HST controls ... And your tractor apparently goes quite a bit faster than mine, I think 17.1 mph is the fastest I've ever seen ... But, you've also got more weight in the loaded tires than I have with my wheel weights. So, that definitely has an effect on uphill travels in H range.
/ 1758 Review
The listed shipping weight of this outside wood boiler is just over #1800. As you can see I have borrowed extended forks to slide over my pallet forks and I am lifting from inside the fire box with the forks as far inside as I can go until they bottom out on back of fire box. Lifting from the bottom isn't possible as the sheet metal will crush. Fleet Farm loaded this with a smaller forklift in the same fashion. My tractor will only lift two legs off the trailer. Not even close to be able to move this boiler. Are physics hurting me that much with this attempted lift? Dealer checked loader spec and has it dialed up to the max. What the **** is going on here? Am I expecting too much being a skid steer guy???
/ 1758 Review #31
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=418668"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=418669"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=418670"/>
I think you're gonna have to find a way to lift from the bottom, maybe using some wood blocks or something to buffer the contact points. With my loader anyhow, she seems strongest from 1'-3' off the ground.
You ever get the loader spec manual? I've verified lifting roughly 2400 lbs (plus pallet and forks) with mine.
/ 1758 Review
Dealer ordered another manual they mailed it to an old address and I have yet to see it. So based on the height and distance out with the long forks would you think I could have a #600 handicap? Guess I was always used to lifting stuff so heavy that the machine would teeter limiting the capacity but the loader was never maxed out
/ 1758 Review #33
Hard to say ... My brain wasn't built with advanced mathematics in mind lol. We still have to remember that the loader is different now, so it's possible that the new model loader isn't as strong as the previous one. Remember, I did find one place that listed the max weight as less than what my loader lists.
regardless, no tractors in this class will offer the lifting strength of a skid steer. Unfortunately. But with that said, I wouldn't really be comfortable lifting any more than I have, stability suffers
/ 1758 Review #34
At the ground, the loader has the best leverage. As the loader is lifted, it typically loses rating.
Can you curl it up?
If not, try using a spacer with some wood on the resting on the forks to lower the loader as much as possible, and then try lifting.
/ 1758 Review
No curl, only able to lift the two legs off the trailer closest to the tractor. As I bring the forks up at the tips to level the load it just runs out of steam
/ 1758 Review #36
Then pick it up from the bottom resting the forks against the round-stock brackets on the inboard side of the legs where you r loader has much better leverage.
/ 1758 Review
Borrowed this to move the wood stove, rated for #3300 lift, it's a brute.
/ 1758 Review #38
My 1643 has a lift rating of 1,300lbs 20" in front of the loader pins. We regularly move big round hay bales (5' dia) that weigh 1,400-1,600lbs with it. Having said that, the loader can't really lift them, we just slide the forks under the bales and curl, then drive over to a small dirt mound and run the forks up it, effectively helping the loader lift the bale. Once the bale is about a foot or two off the ground, we slooooowly drive over to the feeder and drop the bale off.
It seems as though MF loader ratings are quite legit in that they don't overstate capacities. If anything, they understate them.
Anyway, I went from a 1540 with the Powershuttle to this 1643 with HST. I miss the quietness and power of the 'shuttle, but for what we use this tractor for (plowing snow, using the forks to move pallets of wood, brush hogging, loading dirt), the HST seems to be the better choice. I've got about 125 hours on it so far and I'm pleased with it. Never did figure out the rattle noise, though.
Congrats on your 1758, BTW. That loader looks funny. I thought that tractor came with the DL130? What's a DL135?
/ 1758 Review #39
Woblin ... AGCO just switched suppliers for the loaders. Soo Tractor (Radius Steel Fabrication, Sioux City, IA) was the previous supplier. They made your DL120, my DL130, and the rest of the MF, AGCO, CAT Challenger, etc loaders. Now, they are using ALO-Quicke. No one has seen the official specs yet for the new DL135. I had found something that suggested the weight capacity dropped a bit. But, the DL95, which replaced the DL100, is rated for more weight than the 100.
I agree that MF underrates their loaders ... I am continually impressed with mine. Here's some shots from today:
/ 1758 Review #40
I'm digging your color change.
2012 Buick Enclave (A62613)
2012 Buick Enclave...
24in. Terex Excavator Bucket with Teeth (A64194)
24in. Terex...
2011 Ford Explorer (A64127)
2011 Ford Explorer...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
2007 Volvo VNL Truck Tractor (A63689)
2007 Volvo VNL...
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A65054)
2016 INTERNATIONAL...
