CRUNCHING REAR HUB?
/ CRUNCHING REAR HUB? #1
stuiedavis
dublin, ireland
international 674
Hey folks!
my international 674 is going well... but!
there is a grinding sound from the left rear hub... im thinking that its the
wheel bearing... new to tractors and before i go getting wheel off to inspect
id would appreciate if anyone has had this type of issue and how they solved
it?
i have been looking online and cant find international 674 rear wheel hub for sale!
thanks for reading
/ CRUNCHING REAR HUB? #2
Check to make sure the wheel rim bolts are good and tight. Hopefully that's what it is, and not a bearing going out.
/ CRUNCHING REAR HUB? #5
That bearing has a 21MM I.D. A rear axle bearing for your tractor is much larger. Forget the bearing until you check the wheel.
hey folks
i have the wheel off... the nuts came loose by just standing on the rachet and a wee bounce
thought that it would be much harder but they were tight... there is a little in and out play when i pull/push the disc
forgive my ignorance on this but i cant see how to get disc off to expose hub!
again thanks very much for the help... its much appreciated
PS im picking up an international front loader tomorrow :)
i cant see how i get the cap, disc, hub off to expose bearing
ah the whole half axle comes off!
outer bearing knackered
part ordered :)
2022 EZ-GO ELITE...
2011 International DuraStar 4400 18ft. Cab and Chassis Truck (A64194)
2011 International...
2001 Freightliner FL112 T/A 5 Car Hauler Truck (A64194)
2001 Freightliner...
2008 Ford F-350 Crew Cab Emergency Service Truck (A64556)
2008 Ford F-350...
(APPROX. 29) ASSORTED ROUGH SAWN PINE (A64276)
(APPROX. 29)...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
