How Many Hours on Your Kioti?
   / How Many Hours on Your Kioti? #82
257 on my CK 20S Manual. Solid tractor and I have worked it hard.
   / How Many Hours on Your Kioti? #83
4 hours!!
2015 RX6620PS
Cool! Congrats on your new tractor. And Welcome to TBN. Can you start a thread and post some pics of your tractor for us to drool?:thumbsup:
Thanks,
CM
   / How Many Hours on Your Kioti? #86
Hi all , my Kioti DS 4510 is now 3 years old now. When it was 2 months out of its 2 year warranty one of the welsh plugs sprung a leak. I removed the welsh plug and was amazed to find it had rusted very badly and had concerns about the remaining plugs, luckily the leaking one was easy to access but it is troubling not knowing if the others would go the same. I contacted the dealer where I purchased it knew and they never even returned my call.i have not had any other issues but the customer support here in Brisbane is very poor, I recently contacted the main Kioti branch about purchasing a subframe for a backhoe and that also was a waste of time, he didn't even know what the subframe was for or how much it would cost! If I had my time again I would NOT buy Kioti.
   / How Many Hours on Your Kioti? #87
Kioti Corporate is not going to know what a subframe costs. That's something you need to talk to a dealer about. A complete backhoe assembly will go from about 6 to 9 thousand US dollars right now, don't know what the conversion and/or upcharge would be for AU. Remember too, you can get a bad, or great dealer with any brand. Hope this helps.
   / How Many Hours on Your Kioti? #88
My '09 CK20HST has 353 hours with zero issues so far - a really hard-working little tractor :)
   / How Many Hours on Your Kioti? #89
I'm 3 months short of three years ownership of mine and I am at 305 hours. Most of that is winter snow blowing. Even with the minor hiccups along the way, I think I have a good-un.
   / How Many Hours on Your Kioti? #90
DK40 HST has 907 hours.. Starter switch had to be cleaned with electrical contact cleaner then I put some electrical grease on the key and poked some in the switch..
Most of work has been with loader. Flawless.
I did have to put a piggyback oil plug as I stripped the original. Re threaded pan, installed the piggy and now hold a wrench on the main to keep it tight and drain from the insert plug...
1989 CATERPILLAR 963 CRAWLER LOADER (A52707)
1989 CATERPILLAR...
20702 (A51694)
20702 (A51694)
2019 FORD TRANSIT VAN (A52576)
2019 FORD TRANSIT...
MERCURY VERADO ENGINES (A55758)
MERCURY VERADO...
2018 FREIGHTLINER CASCADIA 126 SLEEPER (A57880)
2018 FREIGHTLINER...
Hercules Pesticide Applicator Tank with Nozzle (A55852)
Hercules Pesticide...
