How Many Hours on Your Kioti?
   / How Many Hours on Your Kioti? #122
I have a 4 year old dk50 se with 600 hours. Used to clear land, moved 100's of yards of fill, a lot of grapple and backhoe work, stump grinder, logging winch, pto generator and too many other tasks to list. It has been rock solid and worked hard. I love it
On another note I just changed the oil and had an analysis done by Blackstone. They stated wear metals were exceptionally low and had a TBN of 7.7 at 100 hrs on the oil. This indicates a great running engine. I use Rotella 5w40. I use Amsoil ATH in the Hydro.
A PTO generator is on my list. Are there generators that run at less than 540 pto rpms? Doesn't seem efficient to have to run the tractor at 2000 engine rpms for hours on end.
   / How Many Hours on Your Kioti? #123
I think you can get a gear box to accomplish that but you would lose some torque under heavy load
   / How Many Hours on Your Kioti? #124
4.2 hours. But I only got it yesterday!
   / How Many Hours on Your Kioti? #125
119 hours but just got it in mid April.
Yesterday and today felled two 50' hackberry trees. Wrapped a chain around them and the NX just chugged along and brought each one under some shade to trim down and load up for disposal.
really like how the machine just has the Ummph to get it done.:thumbsup:
   / How Many Hours on Your Kioti? #126
2001 DK55 with 2700 hours. I have to constantly work on it and have replaced a lot of parts. The issue I have is with the factory support, not dealer. I live in Michigan and am not too far away from Michigan Iron. They are very knowledgeable and a great resource. As for the Factory, the repair parts listed on line are poorly written and confusing. The major components, such as the power steering valve, steering cylinders, hydraulic pump and so on should be rebuild-able but you cannot get the parts from Kioti. The repair manual shows how to disassemble the major assemblies, you just cannot find parts. I also have a few older Ford tractors that run forever and every little piece is still available. 2700 hours on a Ford is just broken in, the Kioti is worn out.
   / How Many Hours on Your Kioti? #127
   / How Many Hours on Your Kioti? #128
41 (up from 39 in May, lol). Went through first regen at just over 39 (39.something).
2014 Kawasaki Mule 600 Utility Dump Cart (A55973)
2014 Kawasaki Mule...
2023 CATERPILLAR 299D3 SKID STEER (A52707)
2023 CATERPILLAR...
2020 JOHN DEERE 333G SKID STEER (A52707)
2020 JOHN DEERE...
New Holland B95C (A53317)
New Holland B95C...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A57193)
UNUSED RAYTREE...
2005 Dodge Ram 4x4 Crew Cab Pickup Truck (A55852)
2005 Dodge Ram 4x4...
