How about some more photos? The whole tractor, engine id plate, head and valve cover, maybe the dashboard. Or is it in a forklift or something?Hi, I am currently looking for a head gasket for Yanmar engine. Does anyone know this head gasket is for which engine model?
My guess is that he is trying to buy one off ebay or something and the seller does not know what its for?? and he does not want to give his link away fearing someone may snap it up?
Why else or for what other reason would you not list the tractor even let alone the engine ID ?? wwith that he could just buy from one of many sources for parts maybe enve Yanmar USA if its an american model? Or Hoye tractor would probably be the best and fastest...then you have Frederics???
This is a strange post
Wow, you read TBN on a 72 inch TV?Wow, those pistons look big, about two feet across.
Dave
I see a few thousandths over 2 7/8" on that vernier scale.
jefferycks, where is miri?
How do you know your gasket is for a Yanmar engine????Hi, I am currently looking for a head gasket for Yanmar engine. Does anyone know this head gasket is for which engine model?
The distance between the Cylinders are way off. Twice as big on the Old HG. than the 3t75u new one. I don't believe that's it. Maybe the Same Eng. but with a larger Cyl. Bore. Jefferycks is showing 73.5.mm so that will be easy to check if it's the correct one.
