Garage Floor Cleaning
/ Garage Floor Cleaning #1
sld
Midwest
Ford 1210 / Ford 1710
I've recently started cleaning up the attached garage and have some old oil / grease stains on the floor. I've tried many things but have yet to get them to "lift" out. I've tried power washing, Tide detergent, mineral spirits, etc.... Tire marks are still there too.
Anyone have any experience as to what really removes old oil stains from concrete? I don't need it perfect but the cleaner the better. I now am parking 3 cars in there that have no leaks. The main culprit was my tractor at one time but that has now been fixed.
/ Garage Floor Cleaning #2
I've used a stiff bristle brush and Simple Green, but in view of what you've already tried, I doubt that it would do any better.
/ Garage Floor Cleaning #3
I have used Muriatic acid to clean concrete. works very well but need lots of ventilation.
Using a diluted solution may be what you need.
Does that actually remove a layer of concrete? If so, how much? Noticeable to surrounding areas?
I do have some slope to the floor for drainage so it has been a challenge to get liquids to stay put for very long.
Thanks for the replies so far as all are welcome.
The cleanest spot so far was where I used the brush and some Tide. Worked great for dirt but not so good on oil. And I don't want to do the entire floor with the little brush I have! :laughing: I might rent one of the round buffing machines though.
/ Garage Floor Cleaning #6
I'm almost positive Muriatic Acid will not touch your old grease/oil buildup.
It will definitely etch your concrete if improperly used.
I'm kinda picky about my shop floor. I don't allow any oil/grease to stay on the floor. I use a LOT of floor-dry. Even with that consideration I still have oil stains. No buildup, just stains. Hydraulic oil is the worst.
I'm afraid you may already have it as good as it's going to get. :(
/ Garage Floor Cleaning #7
I have used TSP (TriSodium Phosphate). It is sold in hardware stores. It is usually a powder so you can make a paste and let it sit for stubborn stains. I used it on an oil stain on my asphalt, it took off the stain and the sealer underneath the oil.
Have you tried dish soap with a stiff push broom? The best soap I have found is Sunlight for oily messes.
/ Garage Floor Cleaning #8
If it's meant to be "clean space" and not "work space," consider putting down Racedeck tiles (or one of their competitors). They're easier to keep clean and you won't see those stains anymore.
/ Garage Floor Cleaning #9
+1 to this:
I had some bad oil stains on the floor of the garage of the house we recently bought. On the side where the shop is (no cars) I wanted to paint the floor. I let the concentrate sit on the stains for a while, then took a hard bristle brush to it with some HOT water right out of the boiling tea kettle. Used a shop vac with a wet-vac nozzle to pull everything out of the crevices, and then repeated. After a good rinse, the spots were much less visible, AND the floor took paint with no problem. Maybe give that a try?
But like Bird said, if you've already tried other cleaners, maybe it won't work for you.
I have read about the TSP and might pick some up and try it. I've tried the dish soap and hot (not boiling) water. It's hard to get good scrubbing action with the push broom.
The rest of the floor is pretty clean except for the oil spots. I'm not sure they will ever come up and I'm ok with that. At least it's clean enough to lay on as I will occasionally change oil in this garage.
Those Racedeck tiles look really nice. I have about 700 square feet so I'm not sure about the price.
It's funny, people will tell you that paint won't stick very well but wherever I've spilled some it never comes off! (at least not very easily)
Thanks for the tips. I was hoping there was a magic bullet.
/ Garage Floor Cleaning #11
My BIL bought some very expensive concrete paint. Can't remember the brand name. Did everything by the book. Even let it sit for a week after applying before parking on it. Parked his 1/2T pickup on it overnight. When he backed out the next morning the paint he was parked on stuck to the tires and peeled off the concrete. He called the company they gave him nothing but excuses. Now the only place there's paint left on the floor is where he doesn't use it. :(
/ Garage Floor Cleaning #12
If you rent on of those round floor scrubbers, I'd really like to how well it worked.
/ Garage Floor Cleaning #13
I use cheap cat litter on oil spills / stains. The dustier the better. I lay it down and it soaks up oil spills. It also works on oil stains. Put it on the stain and let it absorb the oil. The next day brush it around or grind the dust into the floor with your shoes and let it sit another day. Then sweep it up. Portland cement will also suck up the stain.
I have not tried this but it's supposed to eat oil off floors.
BT200 Stain Remover and Degreaser
There are also many concrete degreasers available in auto parts and big box stores.
I'm surprised the Tide didn't work. That would have been another option.
/ Garage Floor Cleaning #14
I also use the cheap kitty litter, throw it down and grind it in with your feet until there is nothing left but powder. I use Purple Power and/or Citric acid, broom around and pressure wash. As far as detergents, Dawn is one of the best for grease/oil.
Works for me anyway.
/ Garage Floor Cleaning #15
Yep, Dawn is awesome. I use it in my Power Washer when washing equipment.
/ Garage Floor Cleaning #16
I love my Simple Green, but I agree that Dawn is some impressive stuff. I don't know what makes Dawn technically different from Joy or the others, but if you look around the web at some of the "alternative" uses for Dawn, it seems like pretty magical stuff... a few of my favorite alternative uses are:
  • Wash excess hair coloring from your hair
  • Kill fleas in carpeting
  • Repel insects from house and garden plants
  • Kill ants
  • Treat a yeast infection (really???)
  • Prevent eye glasses from fogging up
Wacky Uses: Dawn® Dishwashing Liquid
/ Garage Floor Cleaning #17
Oils will soak into the concrete and there's nothing you can REASONABLY do to get it all out.
That said, there's a couple of less reasonable ways.
(1) If you seal a hose to the concrete and apply a vacuum condition to it, the oil will slowly flow out. We're talking days to weeks for that though.
(2) Other way is to get water to up well through the concrete from the bottom, and carry the oil with it. Long periods of flooding can do that for you. If you've soaked the area in detergent prior to the upwelling, it works even better.
Short of that, jackhammer the floor out, re-pour, and then seal it before using.
/ Garage Floor Cleaning #18
Carb cleaner works great on recent oil stains in concrete, but not so sure about old stains.
/ Garage Floor Cleaning #19
If mixed as recommended it will not remove the concrete. I use a garden sprinkler can to spread it and then a broom to move it around to the corners and make it even. My floor had not been cleaned since the house was built in 1960. Before I moved in it was covered in dirt and oil stains. The acid cleaned it to like new condition. Then you need to apply a sealer to keep it clean.
/ Garage Floor Cleaning #20
Mm
Short of replacing the concrete you may be stuck with oil impregnated concrete floor.
Soap and hot water should remove the surface oil but underneath there is still lots. Heating may remove a lot of oil but may also destroy the concrete surface.
Cleaners and such will get surface oil but again the oil is probably soaked well into the concrete.
2012 Kenworth T660 T/A Sleeper Cab Truck Tractor (A64194)
2012 Kenworth T660...
2025 BS43 44in. Hydraulic Boxbroom Sweeper Mini Skid Steer Attachment (A64553)
2025 BS43 44in...
2019 Ford F-450 Liftmoore 1032 3,200lb. Crane Service Truck (A64556)
2019 Ford F-450...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2013 Hitachi ZX160LC-5N Hydraulic Excavator (A64553)
2013 Hitachi...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64194)
2015 Peterbilt 567...
