Can anyone tell me if my Kioti CK20HST can push a rear mount 7' snowblower?
Would I need chains, or just use the 54" one?
Thanks,
Trev[/QUOTE
You should get the smallest available to cover your tracks. Get the toughest available.
You'll bog down in 2' of wet snow so you'll have to skim 1' at the time.
Forget about going to 7'. I have 65HP on the PTO and my 92" blower cannot do more than 18" in one pass.
In retrospect, I should have gone 84".
I don't understand the smaller blower, cause the bigger goes too slow logic.
For a horsepower, you're moving a certain volume of snow. Period.
Bigger=slower ground speed, but hey, it's bigger so it's moving the same volume of snow.
I sized mine for 2-trips. Up and back on my driveway. Bigger is of minimal gain, since I still have to go up and then back. If its so small that I have to go up and back twice, that's a waste. If there's 2' of snow, I'll go 0.5mph. If there's 6" of snow, I'll go 3.5mph. Big deal. It's pretty natural to assume if there's 4x the snow depth it'll take longer and you'll have to go slower.
This all assumes an HST. Gear ratios are certainly a compromise. And of course, there is some physicality limit where the blower will "manhandle" the tractor, that's bad.
If your tractor stalls, or when your shear bolt goes you'll be going at 0 mph.
Narrower blower is easier on the tractor.
Harder to get stuck.
If you ever cleared 12' of snow from your driveway, you know what I mean. Winter 2013-2014, I had 12'+ on mine, I could not reach it with my loader. I wish I had more power (JD 5083e) or a smaller blower.
Not sure why that would be. Tractor abuse would be way (way way way) more operator dependent than anything else. The loads are nowhere near the material limits.
Not even sure how I'd go about it. The only proper equipment for that seems like it'd be a loader-mounted hydraulic/PTO blower.
Maybe it's just me....... 100% happy with my "oversized" blower and wouldn't have it any other way.
Less stuff to blow per ft of driving
You'll be ok clearing anything under 2', but if you get more snow than that and have a long driveway to clear, you'll wish you had a smaller, heavy duty blower just to cover your tracks.
Thanks,
Trev
I agree that a 7' is big. IMO a 6' would be ok though.
Chains are a huge help too.
We have a 7' on the back of our L3830 (about 35 PTO HP, powershift transmission) and it will lift the nose of the tractor off the ground if I don't have weight on the front. HP wise, anything more than 12" of heavy snow will bog the L3830 down to where I have to stop every 2-3 feet.We use 7Ft blowers here on the DK and the International, both machines have at least 2 times the PTO HP you have and you must also consider the weight you will be pushing around. About 900 to 1200 LBS for the bigger blowers you might have to think about adding front weights
I would recommend no more than 6' on your tractor and a 5' would probably be a better fit.
Aaron Z
First gear in reverse, runnign wide open (no load speed of ~613RPM on the PTO), I stop to let it catch up when the PTO RPM drops below ~370RPM and it isn't letting up.I am not familiar with the specs of the L3830 but wonder how fast your trying to go with that much power bogging down by a few hundred RPM should not be a problem. We must remember that the volume of snow our blower is designed to handle is the limiting factor for a given HP range and trying to move more volume than it can handle will bog down just about any machine. If for chance you are extremely over powered for the blower you would probably bust the shear pins rather than stall but the same limiting factor of the volume will still apply.
I run a 54 on my 20 and it can have a hard time with that. Slows/bogs the engine down in 12 inches of heavy wet snow. Have to crawl at times.
