Household Septic System
/ Household Septic System #1
jlgurr
Bostic, NC
Massey Ferguson GC1705, John Deere STX46
Been seeing a lot of messages about septic systems lately so it appears there are several of you who might have some advice or ideas for my situation.
We live in a house built in 1978 and I have located a copy of the original inspection of the septic system from the local health department. Ironically the inspector is the father of an engineer who I work with. Since we moved in here in 2005 we have had no plumbing problems whatsoever so hopefully I am not going to jinx myself by bringing this up. Just in case there was a problem I'd like to know where the access to the tank is so we started looking for it last year. No I haven't been looking constantly since then, just saying it's been a while since we started. :D We could not find the tank nor a drain line from the house to the tank.
There is a toilet in the walk-out basement. The ground outside the bathroom wall is within just a few inches of being same as the floor level of the basement.
How much lower than the lowest toilet is the septic tank normally buried? In other words, how deep will I need to dig to find the tank? How far off the sketch is an installer allowed to deviate? Of course, the inspector does not recall my specific installation as I am sure he literally saw thousands of them in his career.
Thanks,
Jeff
/ Household Septic System #2
Our big tank was "burried" so shallow that the cap on the clean-out plug was sticking up through the lawn - about 2' elevation below the first floor & base of the toilet. Since the house was connected to the town's sewer system, many years ago, I dug up the old tanks. They were made of steel mesh reinforced concrete, back in the 50's. If yours are of the same construction, I'll bet a decent metal detector would give you a fair shot at locating them.
/ Household Septic System #3
The fall in the pipe from the house to the tank should be around 1/8" per foot. If you can find the waste line exit from the house it would really help point you in the direction of the tank.
Good idea to find it now while it's not an emergency.
/ Household Septic System #4
<snip>
It is typically within 25 of the house. It is typically a foot or two down from the terrain, but that depends on the terrain. I have seen them a half a foot down and others that were six feet down. You should try to locate the pipe exiting the house, and you can probe along that pipe to find the tank assuming that you have a probe four or five feet long. Bully Tools
/ Household Septic System #5
Without knowing local code? The septic could be anywhere. Starting at a known exit point from the house......The concrete tanks have steel loops on the access ports. A good metal detector is easiest. Depth can vary , but I'd suspect ground level up to 1 foot if it's in the first ten away from the house. Assuming it's a gravity feed system, the farther away from the house, the deeper it would be (~1/8" to 1/4" per 10 feet). When you find the tank and get it open, get the local sucker truck to come empty it (fairly cheap, 250ish here)
/ Household Septic System #6
A probe works, good point. Once we go past 9", we add a riser for the cleanout. Pump-ups, pump-outs get a riser anyway to access the chamber.
/ Household Septic System #7
If you can find out who has pumped the tank in the past they might know. I have both marked mine and measured from two points on the house to identify the covers.
/ Household Septic System #8
If you can access a cleanout in the house you can run a snake down the pipe until it hits the tank. That may give you distance but, better, if you have someone with good ears outside you may hear it hitting the baffle in the tank.
The permit indicates a 1500 gallon tank with 15 feet between the house and the long wall of the tank. Apparently the tank is rectangular with its long side parallel to the house. At the far short end of the tank there are 4 field lines 86 feet long and spanning a field ten feet wide (not sure that is important). I have poked with the inspector's probe all over this area and up to 18" deep with nothing. The red clay next to the house is under a deck which I can walk under and is hard as cement from being so dry for so long. I will need to use a mattock to dig for the house drain pipe. At that point I might need to add archaelogist to my name because I'd have to be very slow to prevent striking the drain line. :D
How tough is the tank? Would a FEL bust it if I was going to slowly scrape away a foot of dirt over the area where the tank "should" be?
Yep, that's why I started looking already. I remember being a kid and dad paying through the nose for an emergency pump-out and it made a nasty mess in the house.
/ Household Septic System #11
Sometimes you can see a difference in the grass over the tank. Because they are often shallow, the soil sometimes contains less moisture and the grass over the tank is dryer or browner.
It could be deeper than 18" or maybe it is closer to the house. I would try using the probe in a line from where you believe it is based on the historical permit and move toward the house in a line perpendicular to the house. I would probe at about 20" intervals.
It seems to me that there should be a cleanout located in the house close to where it leaves.... or just outside. But it could have been covered over in the wall or by carpet if in the floor, or dirt if outside.
I would continue to probe for awhile before I dug with the fel. You may need to get a longer probe. But if you decide to dig with the fel, I would expect the tank and lid to hold up fairly well. You may end up hitting the lid or its handle which is probably a steel rod bent over. It is possible that you would break the lid, but that alone is not the end of the world.
/ Household Septic System #13
Ours is about a foot or so down. The lids are about 6" below the surface. I could tell where mine was because the snow always melts over it first. If we have 3" or less of snow, it will melt over the tank in a day or so regardless if the snow in the rest of the yard melts.
I could also make out the round tank lids in the grass. When I opened it up for the pumper (no problems - just thought it was a good idea to pump it) a couple of years ago, I had no trouble figuring out where to dig.
/ Household Septic System #14
You've inspired me to search also and, after fossicking between the french field & the house, I found it!
It was tricky as the shadows from some trees were obscuring it.
/ Household Septic System #16
Since the tank has been in the ground for a while don't start messing around with a loader you could go through the tank very easily. I just replaced one this winter that a skid steer caved in. Metal detector or probe 12' from house was good advice. The tank edge shouldn't be closer than 10'.
/ Household Septic System #17
You should be able to rent a detector.
I once got one at a garage sale and practiced with it a bit knowing where my tank actually was.
Mine is 7 ft down and that detector located it with ease to the point that I could trace the tank outline on the ground.
In my case the lids are flush with the surface for easy access as by law we need to pump every 2 years. (4 for seasonal usage)
The detector located the metal wire mesh in the concrete tank.
If you are friendly with your city public works they for sure have one and maybe they would help you.
/ Household Septic System #18
Once you find it, add a riser to the opening. Your septic company will thank you as it will make it easy to pump out the tank. I pump mine every 2-3 years to try to prevent any possible problems in the future.
/ Household Septic System #19
THIS. What Mike said. But also check and make sure you do not have TWO openings. Our tank has two compartments, one for the liquids and one for the solids. The LIQUID compartment has the riser which is required by code. The solid compartment does NOT have to have a riser by our code.:confused3::shocked::mad: I had one installed the first time we pumped the tank so that it would be easier to pump in the future.
The problem with the code, is that a homeowner might no know there are two tanks, and the tank you really want to pump is the solid. The code wants the riser on the liquid compartment to make it easy to clean the filter.
I try to pump our tank every Presidential election. Easy to remember that way.
Later,
Dan
/ Household Septic System #20
As I earlier said 2 yrs is law here, 4 for seasonal.
I did have one system that I had personally hand dug, poured concrete, and manually made the drainage field.
It was inspected and approved as well.
I had it pumped for the first time after 22 years of usage and they stated that it was about equal to a a normal 2-3 year usage system.
I would venture to say that all in all I spent no more than $200. to build it at that time. The build would be about 45 years ago
and it still runs great today.
As I gather in some areas you have to add a couple of $00's to that cost for inflation.
SKYJACK SJ86T TELESCOPIC BOOM LIFT (A62129)
SKYJACK SJ86T...
2023 Ferris 500S Zero Turn Mower (A61166)
2023 Ferris 500S...
2022 Mack Granite Dump Truck, VIN # 1M2GR2GC0NM025993 (A61165)
2022 Mack Granite...
2025 KH72 72in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A61567)
2025 KH72 72in...
2016 Ford Transit Van, VIN # 1FTYE1ZG8GKB07239 (A61165)
2016 Ford Transit...
2016 CATERPILLAR 930M WHEEL LOADER (A62129)
2016 CATERPILLAR...
