MF 1428V Will not crank
/ MF 1428V Will not crank #1
Bandit 1953
Humboldt, TN
MF 1428V
My MF 1428V will not crank and keeps blowing the 15 amp fuse in position #4 in the fuse box. Can anyone tell mw where to start troubleshooting this problem?
Thanks
/ MF 1428V Will not crank #2
Does it blow the fuse with the ignition turned, or only when you try to crank the engine?
The fuse blows when you trun the key from the off position to the ignition on position, before you get to the "start" position. The glow plug function is NOT blowing the fuse, they are working OK.
The fuse blows when you turn the key from the off position to the ignition on position, before you get to the "start" position. The glow plug function is NOT blowing the fuse, they are working OK
/ MF 1428V Will not crank #5
I guess my first step would be to check into what fuse #4 corresponds to.
I am not very good with wiring diagrams. The #4 fuse blows when you turn the ignition switch to tje "on" position. I have included the wiring diagram.
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A58375)
2019 CUSHMAN...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
Kholer Magnum 10 Compressor (A61307)
Kholer Magnum 10...
2017 Infiniti QX60 SUV (A59231)
2017 Infiniti QX60...
2020 DRAGON ESP...
