Excavator 'house' Hows it work?
/ Excavator 'house' Hows it work? #1
chopped
New England yankeee
Stupid question maybe but I was wondering how they can get the hyd fluid from the engine to the track motors. Is there some sort of huge round seal on the track assembly? aS it has 360 degrees I assume there arent hoses etc
Thanks. if anyone wants to explain my stupid question lol.
WOW thanks for the info ..It is simple really. I was overthinking it in a different way. Like the track base and the top were more of the 'spool' with some o rings. The video is great. I searched and searched and didnt find it.So thanks so much ..
Also I assume that the whole 'house' rotation is with a big ring gear and a drive motor?I watched a video and as it spun you could ear a loud humm of gears. So Im assuming that how that works?
/ Excavator 'house' Hows it work? #7
The pinion on the swing motor turns on the ring gear mounted to the rotary bearing which is between the carbody and the house.
/ Excavator 'house' Hows it work? #8
I glad you asked the question, chopped. I was wondering about this a few days ago. Thanks to knowledgeable TBN users we now have the answer. Those are interesting videos explaining how it works.
/ Excavator 'house' Hows it work? #9
that's been bugging me for quite a while. Thanks for the question and the answers!
/ Excavator 'house' Hows it work? #10
I've always wondered about this. Ingenious but simple. Thanks for the video.
It is interesting its all stuff that we cant ''see''. Im assuming that this 'rotary manifold' would have to be centered in the disc. But then that leads to another question..Is there some sort of central middle bearing???
And then of cource I wonder are there rollers on the outer side?
/ Excavator 'house' Hows it work? #12
With a crane when you set the house there are hook rollers that go underneath the ring gear. these travel with the house and the ring gear is tied to the track body. Pretty amazing when your talking a 150 ton lattice boom crane.
/ Excavator 'house' Hows it work? #15
Always wondered how that worked. Thanks for sharing.
2005 Kubota L39 (A64126)
2005 Kubota L39...
CAUTION / STOP SIGNS (A64276)
CAUTION / STOP...
Adams 5 T Fertilizer Spreader (A63688)
Adams 5 T...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
2005 Butler pole trailer (A62679)
2005 Butler pole...
2013 PETERBILT 367 MIDROOF SLEEPER (INOPERABLE) (A65643)
2013 PETERBILT 367...
