jd4400 compact tractor pto locked
   / jd4400 compact tractor pto locked #1
GodfreyDaniels
stanfield, nc
John Deere 4400
Rear pto lock indicator light will not go out. Tractor won't start. PTO wasn't locked when problem first popped up. Was told to jiggle the lever so I did. Now it IS locked. Been told the safety switch might be bad. Where is it located in relation to pro lever linkage? Can it be tested for continuity?
   / jd4400 compact tractor pto locked #2
I have a PDF of the Deere Tech manual you're welcome to, has troubleshooting for the switches in it
shoot me your email if wanted
Joe
   / jd4400 compact tractor pto locked #4
on the way
   / jd4400 compact tractor pto locked #5
2011 Chevrolet Silverado 2500 Pickup Truck, 127808 Miles, Utility Rack - GREAT WORK TRUCK (A56438)
2011 Chevrolet...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
2023 FORD F-650 SUPER DUTY CAB AND CHASSIS TRUCK (A59823)
2023 FORD F-650...
2013 Ditch Witch XT855 Tracked Loader (A56438)
2013 Ditch Witch...
2017 Ford F-550 Service Truck (A59230)
2017 Ford F-550...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
