FEL Quick Dump
/ FEL Quick Dump #41
Your document explains the regen quite well and illustrates the same.
I copied your pages for reference.
Thanks.
Like I said, there are four models of that valve as to regen and GPM. You could have any one of the four.
/ FEL Quick Dump #42
I gave my loader manual a read thru last night and found that a regen mode is indicated in the usage instructions. The wording is a lil wonky to me, so maybe someone can decipher.
These are the 2 pages were the regen mode is mentioned.
-J
Does your regen work like it should?
Do you really have a fast dump?
/ FEL Quick Dump #43
That's where I'm unsure. It says I do, but I've never been able to "find" it.
I've always been under the impression that it just wasn't there, but these pages are now making me doubt myself again. I haven't been able to try the method it describes just yet... maybe tonight, definitely this weekend. I'll be sure to post back when I do.
-J
/ FEL Quick Dump #44
-J
If you move your lever slow enough to the right you will find a point to were is pauses... not fully stopped but slows down a lot. then when you go further right it will go fast... its not noticeably faster than the first speed so your tractor is operating normal.
/ FEL Quick Dump #45
It is certainly not much faster than normal dump (which is really slow). I found it telling in the description Shift provided that use of regen eliminates cavitation and thus bucket will have reduced or have eliminated "free movement". I thought that was the purpose of "regen" so as to free up the cylinders so the bucket WOULD move more freely and dump faster. That tells me the valve is designed so total diversion of flow is not attainable. The description further states that valve hook up must be correct to attain regen. How do you mess that up? All bucket movements correspond to the descriptive use of the bucket so where could an incorrect hookup be if the bucket is functioning as it should?
JJ, thanks for your insight and on singling out the possibilities with this scv.
/ FEL Quick Dump #47
Using regen, you should almost double the speed as the pump flow and the rod end flow is now gong to the base end of the cyl.
If you creep the lever to the right, past the soft stop, it might not seem fast, but if you slam the lever to the far right, you should see a big difference.
The regen is not only there to stop the cavitation, and floppy bucket, it will do a fast dump, because you are almost doubling the flow to the base end of the cyl.
/ FEL Quick Dump #48
Ok, I'm going out to the machine now. I can't say I've ever "slammed" the lever to the right but I'll try that when i'm out there.
Shift, I'd want JJ with us for the "slow bucket club" meeting. He deserves a drink or two. Only problem is that I don't thick he'd be willing to come up from Jacksonville to sunny West Greenwich or Foster to visit the Woodland Meeting House even if they do make a great pizza.
/ FEL Quick Dump #50
What are you considering slow? They have pretty quick little buckets from what iv seen
/ FEL Quick Dump #51
With the winter we've had, i think the slow bucket club meeting should be held in Jacksonville, at JJ's pizza joint of choice.
I've not ever timed my bucket, but of all loaders I've used in my life... this is by far the slowest. Loader arms move at a decent clip, but the bucket is just painful. Hence jumping on every one of these threads that go by.... i keep hoping to find something that I've not checked before.
I'll be interested to see what Arrow discovers. I've tried being gentile with the loader handle, found the "pause" between functions as mentioned... but no real speed difference from one to the next. I've also tried manhandling it and tried to get it to "pop" into fast dump (similar to the pop into Float mode for the arms).... nothing.
-J
/ FEL Quick Dump #52
5-7 seconds from full lock to full dump with lever pushed all the way right. I think the manual states a 2 or 3 seconds.
/ FEL Quick Dump #53
Sounds very similar to mine.... but I think we've been down that road before.
I cant help but think that something is off here. Manuals say it's there. Dealer says it's there. Decal says it's there. Where the F is it?
-J
/ FEL Quick Dump #54
I just checked three of them and all were right at 3-4 seconds. How often do yall grease your loader?
/ FEL Quick Dump #55
Also is there any play in the joystick at all before the remote kicks in?
/ FEL Quick Dump #56
I greased my loader about 2 weeks back, maybe 3 now. Its a 3-4 time a year thing for me, if not more.
I don't seem to recall any play in the joystick, but will confirm next time i get in the seat. Should i be feeling a "pop" like i feel when I engage float?
I will add that this is the second loader valve that I've experienced this issue with. The first one on the tractor had an issue where it would not let me curl the bucket with the arms in float mode. Eventually the handle linkage broke, and Mahindra USA replaced the whole valve under warranty.
-J
/ FEL Quick Dump #57
3 or 4 seconds lock to lock? Grease not the issue. Tractor was not responsive to regen from when new. There is no "regen" to this loader control or it is not hooked up correctly somehow. Cannot find serial number when scv is exposed from cover so number must be under a mounting bracket however, gauging from the schematics JJ sent, it looks to have the "regen assembly". Seeing that there are several of us here that are experiencing the same thing, they can't all be hooked up wrong.
Nava, that is making your bucket drops literally twice as fast as ours. Shift, Pilgrim, myself and perhaps others with Mitsu tractors, seem to have real slow hydraulics as they relate to the bucket. The boom is fine, the rock shaft is fine the bucket dump is as slow as a 994D Caterpillar wheel loader which is a giant machine. Something is "irregular" as loader work with these tractors is taking an extra long time.
/ FEL Quick Dump #58
That may explain why the Kabota tractor I was considering when I bought my Mahindra had a half GPM less flow than the Mahindra, but the cycle times on Kabota loader were Half the times on the Mahindra. Undoubtably kubota has a much better use of flow. The Mahindra did have a little more lift, but not enough to have half the cycle times.
You would need to check cylinder sizes to know if this was true. Smaller cylinders on the loader will fill up much more quickly. I doubt that the difference between the Kubota speed and Mahindra speed is related to efficiency. Absent some weird circumstances, it's pretty much just math.
/ FEL Quick Dump #59
On the regen thing, here is a good explanation from kennyd from another site. He is talking green tractors, but I think the theory applies:
Regen is a "feature" of most modern FEL (Front End Loader) valves, it's on the Dump (joystick far right) circuit, and is also referred to as "Fast Dump". The reason it is nice to have is that without it, the weight of a filled bucket can actually "pull" the bucket down faster then the fluid can enter the other side of the cylinder, this will create a air pocket and give the bucket a "floppy" feeling until the joystick is held in the dump mode a few seconds to refill the cylinder pushing the air past the seals. So we add "regen" or "regenerative" function to the valve.
Regen solves this problem by actually filling both sides of the cylinder at the same time with hydraulic fluid. But how will that work you might ask? Well, because there is more volume on the side of the cylinder that extends it since the rod is taking up space in the other side, it "overpowers" the rod side and lets the cylinder extend-thereby dumping the bucket. So since now both sides of the cylinder are "pressurized", the air pocket can not develop, eliminating the "floppy" bucket syndrome. One other added bonus is that the bucket actually dumps faster due to the higher flow rate required to do all this, that's why it's referred to as "fast dump" sometimes.
So, now you may be asking "this is cool and all that, but why do I need to know about it? The answer to that is simple, if you ever try to run a snow plow with two SA (single acting) cylinders, or a cylinder that drives a chute rotator on a snowblower you will soon find out that they won't work if you push the joystick to far right in the regen mode. The plow won't work because since both lines are pressurized-both cylinders will be trying to extend at the same time binding everything up. The rotator won't work because there is no weight pushing the cylinder closed like there is on the loader.
On most, if not all John Deere tractors there is a lockout the limits how far the joystick travels to the right to keep it out of the regen mode.
/ FEL Quick Dump #60
Both the max and the 3016 take right around 4 seconds from full lock to full dump. I checked about 3 of each. You will not feel a bump or change in the lever when it regens. When yall operate the lever start pushing to the right very slow and about halfway you should see the bucket pause. then keep going and it will start dumping again. Its hardly faster than before the switch but it is just a bit. When you use the float it will take away all functions of the loader this lets the weight of the bucket and loader float while back dragging. If that's what you ment by no tilt while in float mode.
2000 Dodge Ram 1500 4x4 Ext. Cab Pickup Truck (A61568)
2000 Dodge Ram...
2015 Ford Taurus Sedan (A61569)
2015 Ford Taurus...
2020 Hino 195 PacMac Rear Loader Garbage Truck (A60352)
2020 Hino 195...
2019 John Deere R-4038 (A61306)
2019 John Deere...
LandHonor LHR-RF24 Ratchet Tie Down and Flatpack Toolbox (A60352)
LandHonor LHR-RF24...
INOP/NON-RUNNING 1997 GMC T7500 Truck, VIN # 1GDJ7C1P2VJ505340 (A61165)
INOP/NON-RUNNING...
