Tiller Rotary Tillers - Sicma Phoenix vs Ansung Terra Force
   / Rotary Tillers - Sicma Phoenix vs Ansung Terra Force #52
that is better but nothing about the spring assisited tailgate.i guess i can figure it out tho.when i unpack it i may find a manual anyway. thanks guys
   / Rotary Tillers - Sicma Phoenix vs Ansung Terra Force #53
YJR Series
If you look at the pictures you can see the normal location of the spring. To hold the tail gate open you pull the lower clevis, to free the lower spring, lift, and put the clevis pin above the small spring topside where you want it set. My unit came with two springs per side for adjustment (long one below, and small topside. To put down force on the tale gate you move the spring up on the bottom against the mount and put the clevis pins in to hold closure pressure. Once you get it assembled, you can play with the spring and clevis pin location to get it to do what you want. It is fairly easy to adjust, but a second hand makes it easy. That tale gate is heavy
Now to work on the tines I have a choker chain with a big hook on one end that fits the lower edge of the tale gate and chain it up as high as it will go using the top link frame. You will need to free the top spring up, lift,I then put the clevis pins in the closest hole to hold open, as back up in case the chain slips. On my unit there is a hole in the bars at the correct location for this work.
Hope this helps.
   / Rotary Tillers - Sicma Phoenix vs Ansung Terra Force #54
Here are a couple of photos of the side arms for the receiver mount I fabricated to allow attaching a cultipacker to a YJR080.
   / Rotary Tillers - Sicma Phoenix vs Ansung Terra Force #55
Take a look at ebbkubota second photo above. That is how the springs should be. You move the clevis pins into different hole positions to get more or less pressure.
   / Rotary Tillers - Sicma Phoenix vs Ansung Terra Force #56
Newbie here. I would like to get some opinions on rotary tillers. I have narrowed my search down to two brands, Ansung Terra Force and Sicma Phoenix. I am specifically looking at the YJR series in the 74 or 80 inch widths or the T15 or T20 series in the 72 or 80 inch widths. I would like to stay under $4K delivered, so I might be stretching it with the T20 series. I have measured my tractor (Kubota M7040) tread width and it is 70.5 inches outer lug to outer lug (R1) and 73.5 inches overall width including the bulge of the sidewall.
First would you recommend going with the 80 inch to be sure to cover my tracks or would the 72/74 inch be ok to save a few extra dollars?
Second, It appears that the Terra Force 3rd point attachment connects to the top of the gear box vs the Sicma has a box frame. Is there a risk of the tab on the Terra Force gear box breaking?
Third, Is the Sicma T15 a closer apples to apples to the Terra Force YJR or is the Sicma T20?
Also, any experience with parts availability between the two manufacturers?
I am a firm believer in buying it right the first time, even if you have to wait and save. So, I please welcome any opinions or personal experience between the two brands.
Thanks in advance. -Mike
Hi Mike, I have a smaller tiller than you need however I am using it in glacial till here in Valdez, Alaska. What I have is a Phoenix Sicma T5-40. This one is their severe duty with a chain drive and a slip clutch. I am very happy with it I recommend it highly. Even though I have bounced it a few times on large rocks I didn't get with the chisel plow the only thing I've broken so far is the "V" bolt that attaches the bearing blocks for the three point to the tiller. While my tiller is a 40 inch wide tiller it is perfect for my set up where I use 30 inch beds on 4 foot centers. You can offset this tiller easily you just slide it over by loosening those bearing blocks. One important thing to note though is I got the tiller that has a center drive which allows you to offset either way. some models use a left or right side drive, watch out for that. I got my tiller through Everything Attachments and they are great to work with very friendly and prompt. Great shipping, they shipped all the way to me here in a remote location in Alaska with no hitches. By the way I like the green equipment, using a JD3320. :)
John - Corbin Creek Farm
   / Rotary Tillers - Sicma Phoenix vs Ansung Terra Force #57
Based on some research, it looks the ansung is heavier and has more blades than the sicma but I’ve read that sicma is built very well. It looks like there are lots of ansung fans but are there any sicma fans. I will be dealing with weeds and vines so will need a tiller that doesn’t wrap weeds.
Thanks
   / Rotary Tillers - Sicma Phoenix vs Ansung Terra Force #58
Based on some research, it looks the ansung is heavier and has more blades than the sicma but I致e read that sicma is built very well. It looks like there are lots of ansung fans but are there any sicma fans. I will be dealing with weeds and vines so will need a tiller that doesn稚 wrap weeds.
Thanks
I am very pleased with my Sigma tiller, I am dealing with rocky glacial till not many vining weeds. Although I do use it to chop up my indeterminant tomato vines and cucumber vines in my compost pile. It chops those up without any binding problems at all. Bindweed or kudzo might be a different story though, glad I don't have to deal with that.
CATERPILLAR D6R XL HI-TRACK CRAWLER DOZER (A52707)
CATERPILLAR D6R XL...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
Two Pairs of 8ft Fork Extensions (A53421)
Two Pairs of 8ft...
Nissan CF60 6,000lb LP Forklift (A55851)
Nissan CF60...
2016 John Deere 17 Mini Excavator (A47477)
2016 John Deere 17...
