FEL Quick Dump
/ FEL Quick Dump #21
Regen is a much better description than fast dump. It is only an advantage when you are handling heavy material in the bucket.
/ FEL Quick Dump #22
You might check and see if they removed the regen parts in the cans on the bottom of the valve.
Regen essentially re-routes the flow to the base end of the cyl and also shuts off the rod side port in the valve.
If you ***** enough, they will have to fix or replace the valve.
/ FEL Quick Dump #23
If you have a PB and regen in your valve, all cyl flow exits the OUT port.
However in regen, the rod end fluid is blocked and is sent to the base end, so no fluid is flowing through the OUT port when in regen. Go back to non regen mode and fluid now flows from the OUT port.
Remove the valve OUT hose and place in a bucket and test it.
If your dealer can't figure this out, then change dealers or insist they change the valve for another model.
/ FEL Quick Dump #24
My 115 loader on the 3016 coincides with Shift's assessment. There is no fast dump on mine either. Will have to let them check it out as well. Since it was this way from when I first got the tractor, my feeling was that this is "normal" since I had nothing to go by. According to JJ, something is off on this scv.
/ FEL Quick Dump #25
I would have thought the other way around. Are you saying it won't regen unless there is a heavy load in the bucket?
/ FEL Quick Dump #26
Regen is a valve function, and will cause the bucket to fast dump anytime.
There are times that regen is not recommended, and that is when lifting the front wheels off the ground using bucket curl.
What is the brand of valves used on Mahindra?
/ FEL Quick Dump #27
In fast dump, does it dump under power or are you saying when loaded it bypasses and allows fluid to free flow out faster?
/ FEL Quick Dump #28
I asked my dealer about this once... couldn't help but feel brushed off by the answer.
"I think they just use the same sticker on all the loader valves....."
Service manager passed this little piece of magic my way.... brush off, am I right?
-J
/ FEL Quick Dump #29
On my 3016, if I can read the muddled casting correctly, it appears to be a "Cross" valve on this.
/ FEL Quick Dump #30
The far right position on the valve with regen, is the fast dump and will fast dump when it is selected.
NO load, full load, what ever, regen will dump fast or is supposed to.
ON some Kubota valves, the regen is in the first part of lever movement, and power dump is to the far right.
Power dump on the Mahindra is first half of lever movement to right.
Some loader valves do not have regen, but your manual should indicate whether it does or does not.This is a Cross loader valve.
Directional valve / control / manually-operated - 15 gpm, 3 000 psi | DV - Cross Manufacturing
/ FEL Quick Dump #31
I contacted Cross this afternoon. I told them how my loader is slower, slow and slower with nothing that reminds of a "fast dump". I was told that the scv is acting normally in that it prevents cavitation from drawing out fluid too fast. Shift, the answer you received from Dubay's service manager may have been correct. They may put the same decal on everything.
Even that it states this valve has "regen," surely they jest.
/ FEL Quick Dump #32
mine too.
/ FEL Quick Dump #33
The 115 is just progressive with the lever. That is normal. They are faster than most of the other loaders Mahindra offers
/ FEL Quick Dump #34
This goes for all Max and 16 series
/ FEL Quick Dump #35
According to Cross Hydraulics who seems to provide the scv's for the 16 series, there is no true regen with this control or I should say no regen as we know it. The bucket speeds up a bit but that is all. Apparently, this is considered "regen" by Cross. I was told this protects the cylinders from cavitation and is considered normal operation for the DV series Cross control.
/ FEL Quick Dump #36
Cross DV series directional control loader valve offers extremely low leakage with outstanding load holding capability in a compact, space saving size. All ports
come out the same surface of the valve and it will fi t in a space less than 6” wide. Float and Regen* capabilities, load checks, built-in power beyond and single handle
actuator make this valve ideally suited for the mobile loader market. DV mounts with 2 mounting holes on bottom surface.
*Regen Capability: valve internally routes additional fl ow to cylinder for faster lift / action.
Specifi cations:
• 2 spool (fl oat – 1st spool, Regen* or 4-way,3-pos – 2nd spool)
• 8-10 gpm, 15 gpm, ¾-16SAE inlet / outlet / work ports
• Built-in Load Check Valves
• Adjustable Poppet Relief Valve
• Built-in Power Beyond capability
• Single Handle Actuator (Joystick)
• Parallel Operation with Excellent spool metering
EDP# Joystick # Description Size Price
-- SDV10FRJ 2-spool, 1st 4-pos Float w/Regen, 2nd spool 10 gpm Call
-- SDV15RFJ 2-spool, 1st 4-pos Float w/Regen, 2nd spool 15 gpm Call
-- SDV10F2J 2-spool, 1st 4-pos Float w.4-way, 3 pos, 2nd spool 10 gpm Call
-- SDV15F2J 2-spool, 1st 4 pos Float w/4-way, 3 pos, 2nd spool 15 gpm Call
Look at your model number as the last two do not have regen.
/ FEL Quick Dump #37
That may explain why the Kabota tractor I was considering when I bought my Mahindra had a half GPM less flow than the Mahindra, but the cycle times on Kabota loader were Half the times on the Mahindra. Undoubtably kubota has a much better use of flow. The Mahindra did have a little more lift, but not enough to have half the cycle times.
/ FEL Quick Dump #38
If you have the same flow going into the same cyl, no matter which tractor, the cycle time should be the same.
More lift could be attributed to the set relief pressure on each tractor.
/ FEL Quick Dump #39
Unless the mahindra uses a larger cylinder. That would give more lift at a slower speed
/ FEL Quick Dump #40
I gave my loader manual a read thru last night and found that a regen mode is indicated in the usage instructions. The wording is a lil wonky to me, so maybe someone can decipher.
These are the 2 pages were the regen mode is mentioned.
-J
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A62131)
UNUSED WOLVERINE...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
UNUSED KJ 33'X25' DBL GARAGE STEEL BARN SHED (A62131)
UNUSED KJ 33'X25'...
2004 Chevrolet Tahoe 4x4 (MPV), VIN # 1GNEK13Z24R318274 (A61165)
2004 Chevrolet...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A61567)
2025 GIYI GY-PG72C...
