Trailer Lights Not Working
/ Trailer Lights Not Working #1
seethesun
Clermont, FL
N/A
Hi,
I have read tons of articles and posts on troubleshooting trailer wiring, plus watched several videos. I am still stuck.
So I bought an old, rusty utility trailer about a month ago. The guy I bought it from had wires duct taped and draped all over. When I picked it up, the wiring worked. The next time I tried to use it, they didn't. So here is what I have done so far:
  • Sanded and painted the trailer
  • New tow vehicle harness
  • Tested connector by putting gator clip of continuity tester on ground & probing each pin. Without turning on function (brake, etc) each lit up. I am not very knowledgeable with electricity so I followed an installation video, which didn't mention turning on the function as you test. Just said it wouldn't light up if it didn't work. Articles/videos since have said to turn on the function. So I tested it with the function on and the probe lights up and blinks. The only difference between on/off is when the blinkers were off, the prob wouldn't blink. I am confused why it would light up with the function on or off. Though, it doesn't blink with blinkers off.
  • Bought one of those trailer testers just to double verify (after hours of banging my head) and nothing lit up. I don't know if there is something wrong with the wiring or if the tester is defective. I attached the continuity tester to it and the lights of the tester came on for each pin.
  • New trailer harness
  • I am working with one light right now to test. I ran a ground from one of the mounting bolts to one of the bolts on the trailer jack.
  • Checked to make sure the light I'm using for test was working by probing the light socket and putting the gator clip on the pin. It lit up.
  • The trailer connector side is grounded to a different bolt on the trailer jack.
  • I tested to see if there was a ground there, by putting the gator clip on the bolt of wiring harness (trailer side) ground and touched the probe to the bolt with the light ground. It lit up. Given my experience (very little), this may mean nothing, but seems if there is a flow there, then the ground should be fine on the trailer and that light, right?
  • On the tow vehicle I checked the ground wire (per installation video instructions I grounded it behind the tail light assembly and even went so far as to sand to a shiny surface). I put the gator clip on it and probed the pins. Lights all came on. Again, this was despite the function not being activated.
Any ideas would be greatly appreciated. Everything says to determine which part is having the issues first, but after the continuity tester and trailer tester saying different things, I have no idea which side has the problem.
Thanks,
David
/ Trailer Lights Not Working #2
A lot depends on the tow vehicle... Did you add the trailer wiring adapter to your tow vehicle ? Was it the same vehicle that delivered the trailer ?
Many newer vehicles have the brake & signal lights activated by a computer controller, and as such they are ground enabled. What I mean to say is that a hot fused wire goes to the bulb, the other side of the bulb is connected to vehicle ground thru the computer activation... neither side of the bulb is connected directly to vehicle ground.
So, maybe you need to investigate if your tow vehicle needs a special trailer wiring converter/adapter thingy.
Hope this makes sense.
Pete
/ Trailer Lights Not Working #3
Have you checked the fuse/fuses on your tow vehicle. On my Fords there is a fuse box in the engine compartment.
The trailer marker, brake, and turn signal fuses are there. This has caused me a great deal of aggravation. Trailer light problems, but actually in the truck. :banghead:
/ Trailer Lights Not Working #4
I had similar problems that turned out to be in the trailer to truck connection. There was corrosion in the connectors...............and it seem to work only when I tied some bailing twine to the bumper to hold the connection in place.....that is, even after cleaning each side of the connection.
Cheers,
Mike
/ Trailer Lights Not Working #5
The two major causes I've seen are - The trailer or truck plug is corroded and does not make good contact & the wiring on the trailer depends upon the trailer hitch for ground
/ Trailer Lights Not Working #6
Ya bad vehicle to trailer grounds cause all kinds of problems.
I am slightly confused on the original troubleshooting description.
/ Trailer Lights Not Working #7
Sometimes with an old trailer, it's quicker to just rewire it than to chase down problems. Been there, done that.
/ Trailer Lights Not Working #8
Trying to follow original post, sounds like new wiring was added and trailer painted. If everything was hooked up correctly and connections are good then I would be leaning towards the grounding problem like DFB stated. I know first hand all kinds of goofy stuff will happen with a bad ground. You will have lights lit that aren't supposed to be lit and stuff like that.
/ Trailer Lights Not Working #9
I agree.
Chris
Thanks everyone. I really appreciate the input. This is one of those things where experience would have really paid off and it would have taken me 2 minutes to solve instead of hours over weeks. Short version. It turned out to be the fuse.
So I called my brother, who works a lot on race cars and their trailers. First, I learned the difference between a continuity tester and a circuit tester. Continuity tester just tests the integrity of the wire, so it has battery to provide power. A circuit tester, well, it's what I should have been using. :laughing: It has no battery and tests to see if the circuit is complete.
I thought about it providing it's own power and causing itself to light up after I tried the trailer tester and it didn't come on. The thing that made me pass over that idea was when the blinker came on the light inside the continuity tester did blink.
So my brother had me try my multimeter and it showed no voltage coming out. He said, well, it could be the fuse. Sure enough.
After spending so much time trying to chase down the issue, you can sure bet if I ever have an electrical issue again, the fuse is the first thing I will check!
/ Trailer Lights Not Working #11
We have all been in your shoes. You never learn anything without trying. Glad you got it figured out. I do agree with the other posters to just re-wire the trailer - its fairly simple. I suggest you run your wires in some sort of protective covering, and things tend to get rubbed on and shorts happen. If the trailer has electric breaks, be sure to check the break away switch and on board battery.
/ Trailer Lights Not Working #12
As others have said, a poor ground causes all kinds of problems. When working on trailer lights I use on old extension cord (any wire will do) and clip on end on the ground on the battery and the other end to where ever I'm working for my test light. This way I know I have a good ground for testing.
Al
/ Trailer Lights Not Working #13
The major portion of trailer lighting problems ends up being bad ground, next is probably corroded connections usually hiding under some electrical taped splice.
If you want trouble free splices soldered or crimped but with heat shrink sealed sleeves is the way to go.
Another common problem is wiring that hangs loose underside and gets snagged by road trash.
Once you have assured a good ground, smear grease, Vaseline or some brand of dialectical grease to prevent corrosion.
/ Trailer Lights Not Working #14
And then there's always the "intermittent" problem.
My trailer break lights didn't work. Turn lights were fine. Checked ll the usual stuff, double checked all the grounds. 7 way tester in the vehicle plug showed everything working fine. Checked the wires from the trailer plug back, all worked. Plugged it in, they didn't.
Disassembled the vehicle plug, one blade connection had broken, when the tester was pushed in it worked. If you put the trailer plug in the weigh must have been enough to tip it slightly, breaking the connection inside the plug
Replaced the vehicle plug, everything worked.
/ Trailer Lights Not Working #15
Your fuse may have been fine until you plugged in the trailer with the multiple wiring. Pop went the fuse so the newly wired trailer did not work. Great learning process. Harbor freight has the wiring harness and magnetic lights for 7.99. I use a good set to get my auction junk home.
/ Trailer Lights Not Working #16
I always weld stainless steel bolts (usually 1/4-20 x 1") next to each light and where the trailer connector ground connects to the trailer frame. Since trailer lights always use the mounting studs to ground themselves and the steel they mount to rusts trailers always seam to have problems. I just put a short section of wire from the mounting studs to the stainless bolt with a little grease in them to help keep them and never had an issue with grounding for lights or brakes. You could run ground wires from each light and brake back to the wire harness but that could mean a lot of extra wires.
2007 Komatsu WA200-5 (A64047)
2007 Komatsu...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
Kubota L295-DT Loader Tractor (A66285)
Kubota L295-DT...
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
2010 New Holland Boomer 8N (A62613)
2010 New Holland...
