LED light bars
/ LED light bars #1
Mothgrey
Chesterfield, Va
2010 Kubota B3030
Hello all I'm very new to this I just bought my neighbors 2010 Kabota B3030 tractor. I've use it in the past and when I found out he was thinking of selling it I decided to make him an offer and bought it. There is no cab as I see others have but i have a bucket, backhoe, box grader, rake, plow and grapple. I wanted to add 2, 12" LED light bars to the protective roll bar one facing front and one rear. I figured this would get them up higher and more functional for me. I do a bunch of off roading and use these on my other machines. I figured I could use a Blue Sea water proof fuse block along with a relay i can tie it into a rocker switch. I really don't even know are there high beams on these things as i could tie it into that switch also. Has anyone done this and what do I need to look out for? I never thought there would be such a thing as mods for a tractor but i see a section for that on this forum also. Anything I should go find in that section that is a must do for this tractor?
/ LED light bars #2
Welcome to TBN.
There are many discussions on hooking up LED's.
At the top right corner of your page there should be a google search bar. Try searching on LED and ROPS.
Also it's Kubota, not Kabota.
I personally hope to never own one Kubota again. Two yes, maybe three or four :)
/ LED light bars
Welcome to TBN.
Yep I was just doing a couple things at the same time as my grandson was bouncing on me and not paying attention to the spelling. Didn't mean to offend Kubota owners.......
/ LED light bars #4
I'm definitely NOT offended. I think I got my B7610 for a great bargain in 2009 because the guy spelled it Kabuta or such and it didn't turn up in the CL search engines. But I notice your profile tractor is:2010 Kobata B3030
/ LED light bars #5
You also need to change the spelling in your profile from Kobata to Kubota.
Also, Welcome to TBN.................................
/ LED light bars #6
Welcome, and to answer your question, there is indeed a high beam circuit. Also, I believe you will find a fused circuit, but no switch, just the two yellow wires, going to the inside top back of the rear fenders for future work lights. They end in a bullet receptacle. You can cut the wire coming out of the back of the fuse box, and use that as a switched (its only hot when the ignition switch is on) power source for your lights. The headlights are mostly useless whenever you have your loader on. A member named 4shorts has done some great threads on installing light bars on his Kubotas in years gone by. He also has a lot of Youtube videos featuring his tractor mods, under Paul Short... I grabbed this link to get you connected with his videos... it's not one on actual light bar installations, but gives an overview of his big Kubota.
https://www.youtube.com/watch?v=0MTFZDmgziU
/ LED light bars #7
I just found the harness on the firewall of my Kioti that contained the plug for the headlights, since they are useless most times with a loader, I just cut the low beam wire off and used that for my LED lights I mounted at the top of my roof. Already switched and fused you just have to get (in most cases) a single wire to the lights with ground being the frame. If you still want the headlights then forget this idea ( i don't think you would even see them come on with the LED's on anyway)
Steve
/ LED light bars
Thanks guys for the replies I appreciate it. I'll need to decide what I'm going to do, at the moment I have an extra 12" LED light I took off another toy so thinking I'll add it here. Just too many other projects going on and not enough time. :)
/ LED light bars #9
I understand already having a light bar and wanting to use it. But if you end up buying them, my personal suggestion is get the longest ones that will fit in your rops. I think mine are either 24" or 36". And something else to consider. I originally wired mine to the existing plug in the back but quickly grew tired of it turning off when I killed the tractor. So I now have both light bars running off of their own dedicated power wires from the positive starter lug, through relays, with toggle switches mounted next to the seat. It's probably a tie between these and the ridiculously ugly homemade grapple for being the best mod on the tractor
/ LED light bars #10
I went with 4 x 27w LEDs, two facing fwd, and two to the rear. These are independently adjustable to point in virtually any direction (great for BH work). I wired them up to an independent aux fuse box and the ignition so they wouldn't accidentally be left on with key on. Added two switches to the dash to separately control front and rear. Thanks to 4shorts for the idea and advice.
I think the light bars are cool looking, meaning a lower profile (more head room on ROPS) but how do you focus/point the light? Not necessary? Seems this would be an issue in optimizing the beam direction.
/ LED light bars #11
Hello Mothgrey !! Welocme, and enjoy that Kubota !!
We need pics though..sooner rather than later !
2017 INTERNATIONAL 4300 4X2 S/A 26FT NON CDL BOX TRUCK (A67147)
2017 INTERNATIONAL...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
2007 Mercedes-Benz C230 Sedan (A64557)
2007 Mercedes-Benz...
2011 International DuraStar 4300 Altec AT40C 34ft. Bucket Truck (A64194)
2011 International...
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
SHOPBUILT T/A TRAILER (A64278)
SHOPBUILT T/A...
