Breaking in new B2650HST
/ Breaking in new B2650HST #1
BCWoodtick
British Columbia
JD425GT, B2650HST
Hey there, finally had the new B2650 delivered on Wed. and the manual says to break in slowly but doesn't give an rpm to keep the engine at.
Any suggestions on running for the break in time would be appreciated.
/ Breaking in new B2650HST #2
Speaking from having a B3030, I would try and run at 2,000 for the first 50 hours. If you are using the PTO, then you will have to rev it up for that. I think a new engine is hurt more by lugging it in a lower rpm than running at a higher one. Just my opinion.
That makes sense. I won't be running the PTO but do have the BH77 so would think that would be the same. The book for the BH77 says 75% of max engine speed so thinking about 1900rpms.
Any other hints for breaking in the tractor?
/ Breaking in new B2650HST #4
i wondered if i missed the photos on the new tractor? i didn't see them, but I'm also waiting for a new B2650HST.
/ Breaking in new B2650HST #5
If I remember correctly, the manual said something like "just don't run it wide open" for the first 50 hours.. That's how I interpreted it anyway. Having bought mine in the summer, I ran it mowing while varying the rpm's up and down the scale....up to but ...less than 2500 rpm.
Cheers,
Mike
/ Breaking in new B2650HST #6
I didn't have any implements to run, just a loader with bucket and forks when I got mine. I guess I wasn't aware of any particular break-in schedule but I did find I didn't need many rpm to get the jobs done. Actually at first I preferred the lower rpm for fine movements of the pallet forks. The loader valve does loosen up a bit to allow smoother movements, but it seemed like it took quite a few hours to get there. I changed the oil and filter after 10-15 hours, don't remember which. Tractor runs like a champ with 170+ on it now so I guess I didn't do anything wrong!
/ Breaking in new B2650HST #7
Mine was delivered with two hours on the meter. I fired it up after the delivery guy/salesman left and promptly moved and placed 105 tons of pitrun gravel. I kept the revs just under 2000 rpm for that chore. I changed the oil at 50 hours like the book said and it still runs like a champ at 178 hours.
/ Breaking in new B2650HST #8
I tried to vary the rpms without lugging the eng.. One thing I would highly recommend is to change the hyd. hst filter like the manual states at the 50 hrs. as mine was really dirty . I am going to do mine again at 100 hrs. along with all new filters , new hyd. fluid , and of course the eng. oil and filter as recommended . When I changed the hst filter at 50 hrs. I just plugged the rubber vent with a 16 penny spike and I only lost a very little fluid when removing filter , mostly just what was in the filter . The vent is at the rear of the tractor at the fill point . Good luck, and enjoy your tractor as I really like mine .
/ Breaking in new B2650HST #9
I agree with HEC....Vary the rpms as much as practical. ....... and avoid lugging the engine down. I fail to see why a diesel would be much different than a gasser in that varying the rpms recommended to ensure good component break-in.....Having said that, I immediately went full bore into snow blowing which requires 2500 rpm to operate the blower efficiently..125 hours of mostly snowblowing later and all is fine (and running a woodchipper about 10 or 12 hours).
Thanks guys,
I am going to get a few hours on it this weekend. Looks like I might have a small leak on the BH77 hydraulic control valve under the controls? Tried tightening and seems tight? It stopped the drip but when I tried the hoe looked like it started to leak again? Will have a good look today now that I have some day light. Anyone have any similar experience? Dealer said sometimes things loosen during transport but am thinking is more than that?
/ Breaking in new B2650HST #11
There is no way one of those fittings should have loosened up during transport!
Yes I would think the same. Am using the hoe now and just the tiniest bit of wetness from the fitting... but I did tighten it up quite a bit.
Any worries about over tightening that fitting?
Also is there an O ring in those fittings or just tapered like a brake line? Am new to the hydraulic tractor deal... but am liking it... Lol
Here are a couple pics of the new machine...
I had the wife try it out... might not get to use it anymore... lol
Lol... I will be on the little John Deere 425 with the wagon getting rid of the trees... lol
Sure did a number on the 2 little Cottonwoods. I think I will be getting a lot of use out this one.
Been running the rpm's about 2000ish when using the hoe and seems pretty good. If anyone else has experience on close to the same machine always appreciate anything else to watch out for.
/ Breaking in new B2650HST #16
Nice machine, so far mine has been great. I got mine last November so no real time to break it in before using the front blower. Dealer said warm it up good and use it like normal, no oil consumption. Only other thing I can think of is look things over often, I don't blame my dealer for things being a little loose. They tend to be a little conservative on tightness of fittings and such... Enjoy that machine
2018 Isuzu FTR Landscape Dump Truck (A61568)
2018 Isuzu FTR...
2008 FORD F350 SUPER DUTY DUALLY PICKUP TRUCK (A59909)
2008 FORD F350...
New/Unused Landhonor Mini Skid Steer Rock Grapple (A61166)
New/Unused...
2022 Mack Granite Dump Truck, VIN # 1M2GR2GC0NM025993 (A61165)
2022 Mack Granite...
(2) BUNDLE OF MISC SIZE USED TIN UP TO 31' LONG (A62131)
(2) BUNDLE OF MISC...
New/Unused Landhonor Adjustable Gantry Crane (A61166)
New/Unused...
