cast iron cookware care
/ cast iron cookware care #1
sailorman
Southeast La.
Kubota 2320
Was reading another thread on cast iron cookin ' . Not wantin ' to hijack that thread, I post this .
I have a number of inherited cast iron pans that have been hard caked on the outside with years of gunk and grease . I 'm thinkin' about cleaning them in my gas oven on the "self-clean oven cycle" and then re-seasoning them . I think this may improve the cooking efficiency of the pans .
Any thoughts on the matter are appreciated .
/ cast iron cookware care #2
I did the process you describe with the self cleaning cycle in the oven and it does remove all of the built up crud. I have three more or less complete Griswold skillet sets nearly 100 years old in addition to Dutch ovens, griddles, etc. etc. All of them were rescued on ebay. Tonight I cooked a pot roast in an old Griswold Dutch oven.
After the self clean cycle your cast iron will have light rust on it. I ended up doing multiple other processes, like neutralizing the rust with vinegar, neutralizing the acidic vinegar residue with baking soda solution, wire brushing, scrubbing and in the end curing in the oven with crisco. I have all my cast iron cookware in the exact condition I want. HOWEVER, after I finished my last item, I ran across an article on electrolysis. I would give it a try if I had to do it over. I would start with a test piece. Google it.
http://www.youtube.com/watch?v=0XlsNucmbiE&feature=youtube_gdata_player
I really enjoy my cast iron cookware and would never be without it. I don't like the non stick alternatives due to health concerns.
/ cast iron cookware care #3
I've used the oven cleaning cycle. Always wanted to try electrolysis, but never have. The quality of the old pans is so much better than the stuff you can buy nowadays. Even caked up on the outside, those pans should work great.
/ cast iron cookware care #4
Use coconut butter/oil to reseason... you won't be disappointed! ;-)
/ cast iron cookware care #5
Yes. I use coconut oil to mini-season each pan after each use. Coconut oil is anti-fungal, antiviral and antibacterial. It solidifies at most room temperatures so each of my cast iron pieces are stored with a light coat of coconut oil. It is also good for you.
/ cast iron cookware care #6
Can you post pictures?
/ cast iron cookware care #7
I never would treat MY CI that way... Put that pan in 50/50 vinegar/water for a day or so, and it will wipe out clean... Then re-season it...
I'm still using the CI my parents had loooooong before I was born and I would never treat it to extreme heats...
This guy here, does it RIGHT! Here's part one,
https://www.youtube.com/watch?v=RgsaQ3FdOwY
SR
/ cast iron cookware care #8
SR
Cast iron won't be bothered by those heats to my knowledge. But If you can get the crud off with vinegar, that would be easier. Most of my crud was quite thick.
/ cast iron cookware care #9
I don't like my cornbread cooked in anything but a cast iron skillet. WE have several CI skillets, Dutch ovens, griddles and even a CI muffin pan that makes the same little cornbread that you can get at Cracker Barrel.
/ cast iron cookware care #10
I used Easy Off spray oven cleaner to clean garage sale cast iron pieces. Spray, let sit overnight on thick newspaper, wash in the morning.
I have found "seasoning" cast iron pans with several coats of FLAX OIL to be superior to any other treatment. I use edible "Barlean's Flax Oil, 100% organic". Food grade Flax oil is readily available in health food stores. An eight ounce container will prep pans through your lifetime.
Flax oil is used in the manufacture of paint, which may explain its longevity as a cast iron pan treatment.
After flax oil treatment you can use soap and water washing pans and slickness does not disappear.
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
KUBOTA L3301 TRACTOR (A62130)
KUBOTA L3301...
2004 INTERNATIONAL 7400 20FT TANDEM AXLE FLAT BED (A59906)
2004 INTERNATIONAL...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
