Loader float system
/ float system #1
K man
Quadeville, ont
2014 Kioti CK 30 HST with cab. 2018 Cub Cadet Challenger 750 EPS UTV
Hi I would like to know more on the float system on my Kioti. I was under the impression that you only use it for leveling. Please explain when you use it Winter or Summer. I have a front mount snowblower and wonder if I can use the float when blowing or not. Newbie just learning as I go. Thanks any help or tips would be appreciated.
Gilles
/ float system #2
You can use the float feature anytime you would like winter or summer. You can use the float anytime you want what ever is connected to your front in loader i.e. bucket forks snowplow whatever, to not have any lift from the tractor it will follow the contour of the ground and or dig in depending. Plus you will still have control of the roll back on your attached bucket blade or forks. I mostly use mine for backdraging or if I'm clearing snow or dirt off of hard surfaces. as far as your snowthrower I'm assuming you're removing the front and loader and using the joystick to control it up and down and to turn the shoot I have never had any experience with this application but I don't see why you couldn't use float if you wanted to. Probably would work well on hard surfaces but may dig in on gravel.
/ float system #3
I think the float position would be very useful while using the snow blower.
Floating the bucket while back-dragging on loose soil (while in the full dump position) is a great way to level and grade. That's how it's done with a dozer.
/ float system #4
I use float a lot when loading material (dirt, mulch, gravel, etc.). Set the curl so the bucket doesn't quite dig in and put the lift in float; then you can drive forward filling the bucket as it follows the ground contour.
/ float system
Thanks all for responding. I will wait till next Winter and see how the float works on the driveway for blowing snow. I use it a lot for back leveling and it works great. I am a newbie so I am learning as I go and so far I have learned a lot. The tractor technology as sure improved since my old Massey Harris 22 and International B 275 lol. thanks
Gilles
/ float system #6
Newbie question, how would float react when on uneven ground? My property is still a virgin lot, loaded with rocks, and stumps. Would float help me even if there are smooth surface rocks?
/ float system #7
Floating allows the bucket to follow the "average" terrain. While floating the bucket, high spots are reduced and low spots are filled. After several passes you can level the land.
/ float system #8
HOW is the float position engaged? I was fooling around with a DK45se on a friend's giant farm and when I tried to put the loader in "float" it just lifted the front of the tractor off the ground. What is the secret? What does "detent" mean? Would the float position be ideal for snow plowing? Thanks for any responses.
/ float system #9
The float position is obtained by pushing the lever past the normal lowering position range. It will go into a detent position or otherwise lock into a full forward lever position. This opens the valve so no pressurized hydraulic fluid from the tractor is transmitted to the cylinders in either direction and the hydraulic fluid from the cylinders can flow back and forth as needed allowing the cylinders to extend or retract as the bucket moves up and down following the ground. If you're not sure how to do this, try with the tractor not running and you'll feel the lever lock in the fully forward position. When I use my bucket or snow blade to push snow, it's always in float unless I need it to dig into some hard snow. Another way to get it to dig in while in float is to change the angle of the bucket by lowering the cutting edge a little.
/ float system
Once you see the wheels lift off the ground push the lever further and it will lock into float and the wheels will drop. I use it a lot when snow blowing this way it does not dig the blower into the dirt but rides on top. The blower floats and follows the grade while the tractor moves up and down if that makes any sense.
/ float system #11
Not all loader valves have the float function in the boom circuit. My friend has a NH TN60DA that does not. I suppose this is a cost saving move by NH but it really handicaps the operator. I am guessing it wood be an expensive proposition to replace the spool section with one with "float" circuitry built in.
Darrell
/ float system #12
The DK series has a float. shove the joystick past the down position. You will feel it go past a hard point and then it will stick down. It can require a good shove to put it in float. The first time I did it I thought I had busted the joystick, lever was limp, jammed down, bucket was on the ground. Then I remembered the float position.
/ float system #13
On my Bobcat CT 235 I need to push fully forward and to the right a bit. The system jerks a bit and I know I am in. I can then adjust the curl while still in float. Works great for plowing snow and not digging in wit hthe bucket. I just keep the front lip up about 1/2"
/ float system #14
Float can come in handy back bladeing fill the bucket so it has some weight in it and away you go.
/ float system #15
My tractor has float ability but I have a question about it. I move the lever into float position and the bucket drops. Back dragging it works well. However moving forward after the bucket fills the front wheels will come off the ground. Almost like it came out of float. This is a second hand tractor so I have no idea how it worked when new so I have nothing to compare.
/ float system #17
The boom lift/lower is in float, the bucket curl/dump is not. when you go forward, you jam the bucket edge into the ground, and the geometry of the loader dictates that the front of the tractor comes off the ground. This is really bad for the loader, never drive forward with the bucket angled forward in float, great way to seriously damage the tractor. back-dragging is fine, make sure the bucket is angled forward, otherwise the same applies. If you want to drag going forward, curl the bucket back so it's past a 90 degree angle. This is so if you hit an immovable obstacle the loader and bucket bounce over it, instead of slamming into it and potentially busting something. Think about the way the force is applied and you'll see it. Also remember that only the boom (up down on the stick) is in float, not the curl/dump (left to right on the stick).
/ float system
I have never used the float on the loader for forward movement but do in reverse as a leveler. I mentioned earlier that I use the float on my front mount blower in forward and works great does not dig into my driveway but rides on top of it.
TPJ89 explains it better for using the float in a forward movement with the bucket curled up a bit so not to dig.
/ float system #19
That's why bulldozers have their blades mounted way low rather than above the hood. Mounting up there gives good lift, but poor strength & leverage when attempting to make your tractor behave like a bulldozer.
All tractors do this in float. Bucket digs in a little & due to the loader geometry the path of least resistance is up rather than forward.
/ float system #20
I have a question about tractor loaders that the talk about lifting the front tires reminded me about. If the tractor is on level ground and the bucket is flat why do the loader arms not have a cradle that prevents the bucket from going below the the tire bottom. This would help limit the front tire lift and transfer the pushing forces into the frame and off of the loader arms. Also I think this is how most skid loaders work.
2005 BIG TEX 16 T/A UTILITY TRAILER (A65643)
2005 BIG TEX 16...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
MILLER BOBCAT 250 PORTABLE ARC WELDER (A64276)
MILLER BOBCAT 250...
Frontier Quick Attach Pallet Forks (A64126)
Frontier Quick...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A64194)
2019 Allmand...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
