Nope, not at all.More than half the people I've polled here at work agree that it's odd and a few who live nearby have stated it's an area with high frequency of accidents. Go figure. The other oddity is that from "her" direction there is no indication whatsoever that the left turn has the right of way to that person who is approaching and turning right.
No ramps or interstates in this case. The horizontal traffic is a two lane road and the vertical is simply a two lane road to a shopping mall.
Sent from my iPhone using TractorByNet
The Lady must have tore a few big strips off!
It's all about getting put down by the perceived weaker gender. That is hard for manly men to accept.
The lack of a yield sign does not vindicate you. As others have said, you are still merging into her lane and she had the right of way.
You yield. At that point you are no longer turning right, you are merging left into a traffic lane, which she is already in.
Forget stop signs... how about traffic circles? Seen a few times people IN the circle stop to let others in. Combine that with a traffic light a block way which backs up into the circle... and you have a mess.
Look at this one. Assume North is up. Do you think that traffic that's coming southbound and turning right to go west on the other road, should yield to traffic that's turned left onto the same road from the northbound direction of the main road?
Well, think about a standard intersection -- if drivers coming from the opposite direction are turning to the same side street, the one making the right turn has the right of way and the person making the left turn (across the other lane) is supposed to yield to the right turner. Nobody has signs in that case -- it's just common rules of the road that say the person turning right has the right of way over the person turning left. I think that aspect of it was was the OP found perplexing, and I agree to some extent.
As is the case with the right turn into the mall that you posted the picture of. The writing on the road says right turn only and you cannot (legally) leave that lane once you get past the start of the yellow lines.Further, once your south bound driver is in the curve he is committed to the merge, he can't get out of it. Therefore there is no risk to the one making a left turn that the southbound driver might change his mind and proceed straight.
I believe that is exactly what everyone thinks my intersection is. It's clear the southbound would yield because he is nearly westbound when the other driver meets him at the merge point. Because this is light controlled there is also little risk of another southbound car proceeding straight through. You see where your distance between the turn and the merge is like five car lengths and the merger from the north is already nearing a parallel line with the westbound lane? In my case there is barely one car length of distance from intersection and merge. That doesn't leave enough reaction time and both vehicles are in full turn.
There is one of your examples a few blocks from my intersection and it works fine because drivers expect it to work that way. Merge occurs when cars are nearly in same axis of travel. In my case our vehicles were not and at the least were 90° to each other. That's not a merge, at least not a natural one.
