Buying Advice 1758 Review
/ 1758 Review #1
onceacop
MN
D17 series III, 1758 Massey Ferguson
Have very little time in tractor but enough to say a few things. I have mostly skid steer time with loaders and the tractors were loader less for field work and slipping through the woods in tight quarters. I have owned M farmalls, a 560 and 454 IH, Bobcat CT445, 2615 Massey, D17 AC, Case 55a and a Massey Harris 101.
First impression with running the 1758 is that I will need to change my ways with loader use. A tracked skid steer in the 60 HP range has short loader arms is like a little dozer. I moved snow today after a stint of temps down to -40F. The drifts are hard and banks harder. I see some flex and movement in the 135 loader and realize one needs to treat it carefully. I will never loan this machine out ever. The skid steer I had on occasion borrowed to family and close friends, that always worked out fine. But they are a much more robust piece of equipment for those hammer fisted operators or folks untrained in machinery.
The loader and hydraulics appear fast on the 1758 and there is less whine in the HST trans then what I expected. Engine is smooth and at 2500 rpm it is not obnoxious loud, cab is well insulated. I ran it hard but was satisfied the most around 2100-2300.
Heater worked awesome and kept glass fog free, I put it away tonight with temps around 11F. Garaged it and plugged it in. A word on the engine and the fuel advice I got from the dealer. This tractor froze up yesterday and required a warm service bay overnight to get it running again. Shipped tractors have #2 and possible biodiesel. I was told to run #1 even at temps flirting with 30-35F. Also told to be careful running additives. They frowned on 911. Clean filters, clean fuel, and #1 right away in the fall.
3rd loader function works ok. Button is pushed and then joystick directed left or right to move implement while holding the button. Miss the Catapillar joysticks already. I was worried I didn't have a float but was happy to learn the detent all the way forward on joystick puts loader in float. I ran the snowblade tonight this way, not sure if that is the way to do it or not.
Speakers not great but I have a radio and I am amused to listen to the partial homeland security shut down bul****. Fire all the politicians and hire some realists.
Partial likes so far:
Great traction even in 2 wheel drive
smooth and quiet
8 hours on tach and the regen soot leve shows one bar is all
HST foot pedals easy and spaced nice
great lighting and heat climate system
pwr steering strong
3rd ldr function worked as I hoped
tractor appears to be the highest quality unit I have owned (fit and finish and lack of corrosion on fittings etc)
Dislikes so far:
HST range lever finicky to shift. Sometimes I tap the pedals and jiggle the range lever to get neutral
It appears when I am in 4WD the range doesn't want to go to neutral, will play with that some more
There is some play in the tilt steering wheel. not much but at high speed on bumps it can rattle and make noise.
Three point lift lever has some play in it, that too rattles against the cab molding.
No 4 wheel drive indicator light when engaged
visibility isn't want I am used to (skid steer guy) so hooking into quik tach plate not as easy
release levers for quik tach closer than I would like to my 3rd function remotes on boom
I will get some hours on this and report again but overall I am happy I went with the HST. Moving snow was so much easier going front and back and having the precision to slow or stop. I had wanted to give out info on the 135 loader specs but my manual is for the 130 loader so I will chase that down from the dealer. Will post more on the regeneration process when it occurs and try to maybe video some of that happening. Comfortable with Massey having this figured out and the 5 year warranty helps alleviate some concerns about that. Cheers and thanks for the help and advice I got from this website and members.
Movies click on image
/ 1758 Review #3
Although it looks like the OEM's diverter valve, the speed of your third function may be related to the fluid getting restricted by the port size in the diverter valve housing itself. Nothing in the class can match the MF1700 series 11.6 gpm to the remotes flow which means to replace the diverter valve for an open center third function, you'd want to use a D5 open sub plate and D5 open center electric over hydraulic valve (with ports P and T open to tank and ports A and B blocked) as well as the increased costs custom making hoses from the power beyond port on the loader valve body to the P port on the sub plate, a hose from the T port to the three point or rear remotes (however Massey does it) as well as custom hoses on the A and B ports going forward to the loader.
In other words, you can live with the 3rd function you've got, right?
No matter what, you have the best looking tractor in the class!
BTW, what aircraft is hiding in the hanger?
/ 1758 Review #4
Congrats on finally getting her home and using her.
I was at my MF/Kioti dealer today and BS'ing with the owner ... He said he actually likes the new loaders from Alo-Quicke, and says they have always been "premium loaders" so maybe they will be a hit after all.
She looks good! I'm jealous. I'd love that extra HP.
Regarding visibility, I've often heard skid steer users comment that a tractor offers superior visibility. Do you just mean that the "right in front of you" viewing was better on the SS, or overall?
/ 1758 Review
Thanks guys,,,
Vis..I was referring to the actual hooking up to a implement. The skid steer was close like almost in your lap. The loader is farther out and depending on the attachment you lose a little precision at least for me. I have one attachment that has always been troublesome. Eric,,,,, Super Cub in hangar
/ 1758 Review #6
Thanks guys,,,
Wow, I'd love to get a super cub someday but my flying ambitions are likely going to be limited to getting a powered paraglide license out of that flying school in Alexandria, MN.
/ 1758 Review
MORE:
Another hour on machine. Tach now shows 11.8 total, some of which was dealer time.
HST trans in high range ok for empty roading on the flat. I did not see the top mph in range and tire size according to the manual which is about 20.3... What I did see is maybe 18 with a handheld Garmin GPS unit to determine speed.
I cannot figure out how to convert KM speed on gauge cluster to MPH, no mention of it in manual
Backed up on a grade, maybe 10% in high range with packed snow. Tractor could not pull itself in forward or reverse. My tires are loaded. So medium range is going to be the go to speed for power and most chores.
Still only one bar on the soot level gauge, manual says regen happens at 5-6..
At slow speeds the tractor has a shudder. I assume it's the aggressive tires and possibly the factor of loaded tires; especially with R1's. I have not experienced this before and had other R1equipped tractors. Best way I can describe it is when I apply foot pressure to the HST pedal as the tractor starts to move there is a subtle hopping or shudder in the tractor. I can see and feel it and as I go faster it goes away. Anyone that has operated a 2 cyl JD like a A, B, 730, etc.... those tractors did this at idle because of the pistons, Johnny Pop... That is the sensation I have.
Linkage in the range lever getting better, I still need to apply a tap either forward or reverse pedal and pull the lever at same time. It usually goes right into neutral.
Lighting is really nice, drove it last night. Superb lumens for a CUT
/ 1758 Review #8
I'm wondering if it just needs breaking in, because I can plow snow in H range, including slight grades, and obviously I'm running less HP than you.
Is the shuddering just on pavement? I notice it on pavement, but not on ground, dirt, gravel, etc.
/ 1758 Review #9
To a skidsteer guy, H range is for light use. Most of your work will be M range and/or L range.
I understand your frustration about visibility. You'll get used to it.
Great report. It's important to post thoughts early on, before human nature kicks in, and you simply accept everything as it is. Great report!!!
As for the Tier IV soot level stuff. Don't worry about it. If you are running the machine with load and at high rpm you may go 40-50 hrs before regen. If/when the regen occurs, try to operate the machine at high rpm and with load if possible during that process. That will minimize time in that situation and get a better "clean".
Did I mention great report?? :D
/ 1758 Review #11
Any more use to comment on? I was actually thinking about you today while I was out plowing... in H range, wondering how yours was doing.
/ 1758 Review
We had a few inches of snow so after work I plowed some, lots of drifting but not very deep snows. My tilt steering column still makes noise during operation. There is play in it and I will at some point see if they can address it. Not a major deal but I dislike rattles and such.
I put the tractor away at 7 degrees tonight. Photo above from a few days ago on the runway. Heat and large cab a luxury compared to a skid steer cab. Liking the high up vantage point. Watched a herd of deer come in and feed right at dark. Like sitting in a elevated tree stand with heat.
I did plow in third for a period of time. It will do that. I am liking the throttle linked HST peddles. I rarely mess with the throttle. Doors I am impressed with. Bank vault feel to them when shutting. A fair amount of force needed to get them sealed when slamming.
Turning radius way better than the 2615 I had. In 4WD when I turn sharp there is no feeling of binding or hopping of the front axle. Not sure how they engineered this, but my Case/IH 55a and 2615 did not like aggressive steering with front axle locked. Impressed
Fuel gauge bar graph fluctuated several bars tonight over a course of an hour. Not sure if fuel is sloshing and this is that accurate of a gauge or what.
The loader attach pins nearest the cab rattle at just about any idle speed. They are loose enough a fit that they appear to float in place and rattle making an annoying metallic sound.
Top speed about 18.2 now, trying to break this in and run the paces.
wiper blades worked with nice coverage
still 1 bar on the soot, waiting for it to jump to 2 and so forth so keeping an hourly mental note on that
with the HST trans I use the brakes very little, I mean like only a few time I have touched them..
This video taken by my friend who flew in to say hi,, show the plowing I did. Normal years I would never plow the runway as I have skis. This year the snow depth is so little I am not bothering with ski install on plane...
/ 1758 Review #13
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=414873"/>
Nice property.
So ... She loosening up? Did you make sure to have the dealer check the loader relief pressure (was thinking about that today...)
/ 1758 Review #15
That vid is really cool... Gorgeous property.
I don't have any interior rattles, I know they changed a couple things in the interior, but that's disappointing.
The fastest I can do downhill is 17.1 mph. Plowing snow in H I can see 15 mph.
I'm looking forward to summer when you get to using the loader, I'd like to hear how the new loader is performing.
/ 1758 Review #16
That door slam issue is the kind of things that bug me, along with the rattles. Evidently they didn't build a pressure relief outlet into the cab structure. So when you are trying to shut the doors with the heater fan running you are trying to overcome that pressure. Bummer. Had a road grader built that way once. I was always afraid I was going to break a door window trying to get the door shut, especially in bitterly cold weather.
Nice report!!!
/ 1758 Review #17
That must also be something new with the cab redesign, mine closes really well.
/ 1758 Review #18
Sometimes the engineers aren't very practical. They probably decided to tighten up the cab to make it a more user friendly, dust free environment. So they closed the vents. Deere's fix was to add a ventilation/fan system to their grader cabs. Any time the heater fan is running there is also an outside fan running that recirculates outside air. The doors shut easily. The cab is 99% dust free. Only dust created is what you stir up with your feet while operating. Keeping the floorboard clean eliminates that.
/ 1758 Review
Cut firewood today in a logging area. Green Black Ash. It's heavy, every piece of it. Massey lifted the wood cribs without strain. I'm not so sure it couldn't lift another 1/3 the weight. The loaded tires a plus here. Connecting and disconnecting the third function loader attachments easy and more hassle free than the skid steer. I jiggled the joystick and worked the third function button moving the loader stick left and right before disconnect. Nice and quick. Did a cold start without block heater. Temps in mid twenties. Glow plug cycle not very long and the engine started fast.
/ 1758 Review
2022 BOBCAT T770 SKID STEER (A62129)
2022 BOBCAT T770...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
2023 Nissan Altima Sedan (A61569)
2023 Nissan Altima...
2009 Honda Pilot AWD SUV (A61569)
2009 Honda Pilot...
832726 (A61166)
832726 (A61166)
